Old 08-06-2010, 12:52 AM   #1
isimon91
isimon91's Avatar
isimon91 is an unknown quantity at this point
Send a message via AIM to isimon91
SR20 Part Out
Pick-up only
847 644 0469
I dont have pictures of everything, pm me if you need a specific picture of a part.
Everything here is in great condition, you really get what you pay for.
pretty firm on the prices, everything is priced to sell.
if you have any questions, PM me
-S13 SR20 motorset:
Blacktop head w/ redtop bottom end, cosworth 1.8mm head gasket, OEM manifolds, HKS 264/264 cams, Greddy RAS, comes with belts, alternator, water pump,, stock injectors, ignitor, etc etc. Bought this last fall and barely put any miles on it, near perfect condition. Compression is solid. $1400
-OEM SR transmission:
-Working SR coilpacks, 8 total- $20 each, 8 for $140.
No grinds, used amsoil in it $250
-Exedy stage 2 clutch w/ resurfaced flywheel (>600miles), broken in properly $300
-Earl's Oil cooler setup from TF, comes with the oil cooler, lines and adapters 425$
-TiTek (Denzo) 550cc side-feed injectors, car probably moved further on a tow truck with these than it actually drove, perfect condition. Bought these from TF for $600, asking $350
Stance SR20 oil block adapter $90
-T28 turbo setup w/ lines, zero shaft play, comes with megan t28 turbo elbow(>600miles). $500
-SR bottom mount downpipe $100
-FULL SR harness w/ ECU, Enthalpy tuned to Z32 maf, 264 cams, T28, 550cc injectors, harness$200, ECU w/ enthalpy chipset $200. TF charges $150 alone for a reflash, the chipset costs $400 originally to have installed.
-HKS t25/t28 hotpipe w/ flange$100
-HKS SSQV $100
-HKS coldpipe$100
-Godspeed 3" FMIC$80
-Brand new ISIS Z32 maf, never used, paid $135 shipped$100
-Suede RX8 seats w/ s13 seat rails, perfect condition$200
-Power steering rack from S13, with SR20 mounting clips and pulleys, full assembly$275
-Greddy Turbo timer$50
-Grteddy profec vacuum Boost controller $150
-Apexi SAFCII$150
-SR oem upper/lower radiator w/ hoses, two sets $30 per set of hoses, radiator $50
-3.5" (forget the brand) aluminum racing radiator, fits perfectly in s13 engine bays$150
-Freshly rebuilt SR alternator, looks brand new too$100
-Greddy oil catch can, everything included$50
-SR flywheel, needs to be resurfaced $50
-SR trans gasket $40
-SR water pump $40
-Air filter for Z32 maf $20
-Stock S13 mirrors $30
-Stock s13 coolant resovoir$20
-Stock SR20 FPR$50
-Stock SR20 bell housing gasket$40
-Stock SR20 flywheel$20
Pictures:
1993 S14 SR Powered Hatch: Sold
1989 S13 SR Powered Coupe: Money pit
isimon91 is offline
