Old 10-05-2010, 03:00 PM   #1
erikbanana
erikbanana's Avatar
erikbanana is an unknown quantity at this point
Send a message via AIM to erikbanana
sr wont crank.
so i just bought this s13 with a redtop. everything seems fine drove it and all no leaks and nothing i just have to push start the car.
the guy told me it was a bad battery. but if it was that then none of the electronics or stereo would turn on. im guessing bad starter?. im not sure.
edit: jump starting it or chargin battery dont work. havent tried using a different battery though
erikbanana is offline   Reply With Quote
Old 10-05-2010, 03:25 PM   #2
richard(s13)
richard(s13) is an unknown quantity at this point
well get your battery charged or use another one from another car...and it should turn on if the starter or battery is the problem...but once you have the car running disconnect the positive on the battery if it turns of its most likely the starter i just changed mine this past weekend, had the same problem...thats what i know correct me if im wrong....
richard(s13) is offline   Reply With Quote
Old 10-06-2010, 07:12 PM   #3
benj1159
benj1159 is an unknown quantity at this point
if it has a bad starter your car will not crank, just go get your starter tested, most likely it is a bad starter i would also replace your battery
benj1159 is offline   Reply With Quote
Old 10-06-2010, 07:19 PM   #4
benj1159
if you disconnect the battery while your car is on and it turns off that means your alternator is fucked up
Old 10-08-2010, 01:08 PM   #5
richard(s13)
haha my bad ppl i must of read it wrong...but yea go test the starter that would be the best choice
Old 10-08-2010, 02:31 PM   #6
erikbanana
erikbanana's Avatar
lol starter fine..
the clutch wasnt pushing the button wow ahhaha. so lame
