![]() Join Date: Apr 2003
Ultimate Rotor Thread
so here are the rules...
1) only post rotor specs (car, year, model, diameter, thickness, additional information) 2) do not write what you think. must know for sure. 3) if it is stated wrong on here tell us and the information will be erased and replaced BUT you must provide a link that verifies the source. 4) if there is a car not listed and you know the sizes post it and it will be added. again add a source so we can check to make sure. 5) hope this helps. CHASSIS YEAR MODEL FRONT REAR ADDITIONAL S13 88-on CA18DE/T 250x18mm 258x9mm 89-91 RS13 (180sx) 250x18mm 258x9mm 1.8L turbo 89-94 240sx 254x20mm 258x9mm 91-on SR20DE/T 280x22mm 258x9mm non-hicas 92-on SR20DE/T ? 258x9mm hicas 91-on RS13 (180sx) 280x22mm 258x9mm 2.0L S14 94-98 200sx 280x22mm 258x9mm 95-98 240sx 257x22mm 258x9mm w/ABS 95-98 240sx 252x20mm 258x9mm w/o ABS S15 99-on 200sx 280x30mm 258x9mm 300zx 84-86 Z31 250x20mm 258x9mm NA 84-85 Z31 274x20mm 290x9mm all models 86 Z31 274x20mm 290x9mm NA 84-86 Z31 274x20mm 290x9mm turbo 87-89 Z31 274x20mm 290x18mm NA 87-89 Z31 280x24mm 282x18mm turbo 90 Z32 280x26mm 297x18mm aluminum 91-92.5 Z32 280x30mm 297x18mm aluminum 92.5-96 Z32 280x30mm 297x18mm iron 350Z 2003-on Z33 296x24mm 292x16mm non-track 2003-on Z33 324x30mm 322x22mm track Skyline R32 ? GTS-4 280x26mm ? 89-93 GTST 280x30mm 297x18mm 89-93 GTR 296x32mm 297x18mm 93-94 GTR V-Spec 324x30mm 300x22mm Brembo R33 ? GTS-4 280x26mm ? 93-98 GTST 296x30mm 297x18mm 93-98 GTR 324x30mm 300x22mm Brembo R34 98-on GT 296x30mm 297x18mm 98-on GTT 310x30mm 297x18mm 98-on GTR 324x30mm 300x22mm Brembo J30 90-94 280x22mm ? 2/90-10/92 280x22mm 258x10mm 10/92-11/94 280x22mm 258x9mm Sentra 2003-on B15 v-spec 305mm 277mm Brembo G20 ?-1999-? 280x23mm 260x10mm Supra 93-98 Twin Turbo 324x32mm 3000GT 91-93 VR4 295x30mm 94-on VR4 314x30mm NOTES: 1) You can use the Z32 calipers with rotor sizes of 28-32mm (i.e. Supra, VR4, GTR, etc.). 2) Brackets are needed with use of Z32 calipers with rotors larger than 280mm (i.e. GTR, VR4, Supra). 3) There is a company that makes a bracket for the use of VR4 rotors but pushes the caliper out towards the rims, you will need at least a 15mm spacer for the rims. 4) Some rotors need you to bore out the center hub section to fit on a Nissan hub or add hubcentric rings. UPDATED ON 4/07/05 |
![]() Join Date: Aug 2008
adding some info
2003 altima rear rotors with 1987 300zx NA caliper brackets work on the rear of an S14 with the stock calipers and pads no washers required. Some have verified 85-86 300zx caliper brackets would work. Well I found some brackets from an 87 model and only paid $10 each for them. I figured it was cheap enough if they didn't work then ohwell! It turns out they fit without spacing the brackets.
S14 Turbo LS1/t56 http://www.playloudclothing.com/ |
