![]() Join Date: Jun 2010
Chase Bays Brake Booster Delete and Brake Line Kit
These are currently ready to ship!
1 of the MANY options for prop valve placement... Any questions should be answered on our store description. If not feel free to ask us on here. Chase Bays Brake Booster Eliminator Chase Bays Nissan Brake Line Relocation Kit for CB Booster Delete Thanks for viewing!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 Last edited by Chase Bays; 05-12-2011 at 03:59 PM.. |
$474 + shipping
$249 Brake line kit $225 Booster delete
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 |
![]() Join Date: Oct 2004
This is awesome!!! I need to be able to proportion front and rear brakes...
But I did have a question. That Brake booster only has 1 steel line, whereas our cars uses a line for Left Front, Right Front, and single rear line to a splitter box....... This kit deletes all of that except the splitter box at the end of the rear line?
![]() Join Date: Jun 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
Cause your too lazy I'll do it for you before others start asking.
Functionally the car stops in the around the same amount of time. If your brakes are in working order and are 100% bled properly you will not lose any performance in that department. In this kit the main change is the pedal feel. It is definitely a much stiffer pedal feel and does require a bit more leg pressure. It is still very streetable and very easy to get used to. Not only have we tested it ourselves and proved its greatness but out of the hundreds of customers who have purchased it no one had any complaints. One drive down the street and your used to the changes.
Driftphreak87 |
![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
I will take the whole kit plus clutch line. Please pm your phone number to order it from. I am not a fan of ordering online, thank you.
Do you suffer from vaginal dryness... |
#15 |
This of course would replace your Z32 brake master cylinder.
It works great with the Z32 brakes...we've tested it. ![]() Thanks for the support guys.
#16 |
looking for full kit shipped to 85345 please pm price
#18 | |
![]() Join Date: Nov 2008
thank u ![]() |
#22 |
Working on pictures with motor installed.
Shop number is (205)807-8891 GripTerror, it would work fine. Might have to do some different adjustment on the prop valve but it will for sure work very well.
#24 |
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
A few questions:
1) "a bit more leg pressure" is required for this brake setup... however, it is significantly less pressure than say, if I disconnected my brake booster w/ the stock brakes yes? 2) for the s13 kit, it only replaces the rear hard lines going to the junction box (or whatever piece that is) at the very bottom passenger side of the engine bay, correct? 3) Do I need to have a flaring tool or anything for either the option 1 or option 2 kit (the instructions say a 37 degree flare is needed at some point)? 4) If I want to get a 1" bmc, I can order one from wilwood/summit/you guys, correct? My car is @ 3000lbs. 5) Do you have any base/starting proportioning valve settings for various brake setups on the s13/s14 at all that you can provide customers? THANKS!
bew bews! |
#25 |
#26 | |
1) Correct. Doing that is not the same and is a lot harder to brake than our set up.
2) Correct, our "In engine bay" kit replaces the junction box with a Prop valve. Our "thru firewall" kit requires cutting and re-flaring of the rear hard line. The flare is 37degrees. 3) Read above 4) You could order a 1 inch MC through us. It would be the same total price 5) Yes, we have something good to start off with. A default setting. Quote:
#28 |
Its a Wilwood. The car started as an automatic so we just drilled the holes for the Wilwood CMC pattern. About to upload a picture of the whole setup, its pretty unique.
#30 | |
![]() Join Date: Aug 2006
any pictures of that setup yet?
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd ![]() Boycott Berkeley and code pink |
