![]() Join Date: Jan 2009
![]() okay, I've been compromising a list of things that should be done before the SR is plopped into its respective location. please add or comment on the list I've gather this far. tips, info, etc is very appreciated.
Coolant Temp Sensor Front Main Seal Rear Main Seal Water Pump Intake Plenum To Collector Gasket Nismo Thermostat Manifold To Head Gasket Manifold To Turbo Gasket Valve Cover Gasket Spark Plug Cover Gaskets Intake Plenum To Head Gasket z32 Fuel filter All hoses under intake manifold 4 bolt and 5 bolt turbo gaskets Heater hose new injector o-rings PCV Valve Clutch (pilot/throw out bearing) resurface fly wheel Nismo Clutch fork pivot All belts i think thats a pretty good list for a well done maintenance job. LMK what else or if you have any comments. thanks
RIGHTWHEELDRIVE.com
resealing the oilpan is easy to do after the swap. same wuth bearings. but i dont feel like replacing thoes things. i thought about it tho.
RIGHTWHEELDRIVE.com
#8 | |
![]() Join Date: Jul 2007
i got mine at cost, 30 bucks ![]()
#9 | |
![]() Join Date: Apr 2008
and its not a good idea to cheap out on machine work
1992 240sx (RB20. 362whp@16psi) |
Change the oil pump and timing chain. Those are the two things i regret not changing when i had my motor out. Do i while you have everything apart.
08 Mitsubishi Evo X MR 89 Nissan 240SX |
#15 | ||
![]() Join Date: May 2007
Its a good thing that the damage caused by not replacing either of these are cheap yeah? Cost vs Risk. Is the risk of replacing your motor worth the cost of not replacing these items?
#16 |
![]() Join Date: Feb 2008
Im going through the same process right now. It ends up being expensive but a lot of stuff you might as well do it while the engine is out and apart, such as the timing chain and oil pump. I was just going to replace the pistons. Ended up replacing the rods, all gaskets, bearings, oil pump timing chain, etc.. I say just save up for the extra parts before you put it all back in. Also nissanparts.cc is the cheapest site for most of the parts listed.
#17 |
thenismoshop.com (west covina nissan) also has great pricing for the timing chain and oil pump. it's alot of money but I plan on purchasing those later this week for my swap too.
#18 |
I did just about all the above listed with my SR before swapping, BUT wish I would have spent some more time and thought when it came to cleaning up the engine bay along with wiring while everything was easily accessable. Just my
#19 |
![]() Join Date: Apr 2003
Trader Rating: (32)
![]() Feedback Score: 32 reviews
SPL has a clutch fork pivot cheaper than the nismo. I'm sure its just as good if not better, considering all their other quality parts.
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune |
