Old 10-21-2010, 12:25 PM   #1
Ceepo
Ceepo's Avatar
Check all grounds on the chassis, who did the wiring on the swap for you, are you sure its done correctly, check your cas, check the ignitor(make sure its getting signal in one side and out the other) check the grounds on the coilpack harness, check the grounds for the block/engine itself(EVERYTHING)
spark, sr20 blacktop, tech
