Old 11-03-2010, 04:58 PM   #1
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
Going even lower.
Looking for the best way to go lower than my already maxed out Powered By Max coilovers in the rear. Re-doing rear shock towers and subframe risers are the bottom of the barrel choices.
Some background:
-Car was built with extreme low drift car in mind.
-Powered By Max coils/SPL everything multilink
-Wheels are 18x10 +14 with 225/40 Toyo Proxes 4
-When I was running over -5* of rear camber, there was absolutely no gap betweent rim and fender.
-Went up to -1* and now there's a two finger gap between lip and fender
-SPL toe arms with the bend is two credit cards away from subframe
-PBM coils are maxed.
Not many people on here have the balls to go that low so I'm looking for advice from Marcus, Yuta, Matej, etc. People that have gone LOWLOWLOW.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 11-03-2010, 05:04 PM   #2
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
you could PM those elite members who know all about that low low biz since you specifically mentioned them, oh wait you want that street cred.
hey yall check out nic0!!!! he's bout to steez on you foolz cuz he can go low low!!
240KA is offline   Reply With Quote
Old 11-03-2010, 05:05 PM   #3
lflkajfj12123
Subframe risers will help a LITTLE.
Old 11-03-2010, 05:08 PM   #4
Bubba Chaos
Bubba Chaos's Avatar
Bubba Chaos is an unknown quantity at this point
Pics of current ride height?
Bubba Chaos is offline   Reply With Quote
Old 11-03-2010, 05:14 PM   #5
tanks13
tanks13's Avatar
tanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of lighttanks13 is a glorious beacon of light
Send a message via AIM to tanks13 Send a message via Yahoo to tanks13
^^^^^^what he said!
tanks13 is offline   Reply With Quote
Old 11-03-2010, 05:14 PM   #6
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
marcus is running the subframe risers. Other than that hes done the typical things to go low. Did you flip the front brackets of your max coils? I hear that flipping them allows you to go even lower
ZenkiKid is offline   Reply With Quote
Old 11-03-2010, 05:17 PM   #7
cardoza
cardoza is an unknown quantity at this point
Hope you can get lower in front too because otherwise you'll be having some silly reverse rake.
cardoza is offline   Reply With Quote
Old 11-03-2010, 05:21 PM   #8
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
awww i wanna go that lowwww ):
actually a lil lower
Old 11-03-2010, 05:24 PM   #9
Weedm
Weedm's Avatar
Weedm is an unknown quantity at this point
did you already droop the rears to the max? <-- I just learned what droop meant.
Weedm is offline   Reply With Quote
Old 11-03-2010, 05:26 PM   #10
wh0aitznic0
Lol why do you have sand in your vagina, Oklahoma?
Anyway here's a pic of it before. I did NOT touch the height adjustment but somehow when I removed negative camber, the rear raised up to about where my fronts are. This is my desired height again.
<3
Old 11-03-2010, 05:26 PM   #11
lflkajfj12123
oh yeah
gotta droop dat shit homie
Old 11-03-2010, 05:30 PM   #12
PoorMans180SX
PoorMans180SX's Avatar
Subframe risers are really easy to install.
Plus any lower and you're going to have to push the subframe up so your toe arm doesn't hit/bend.
Or you could get PSM toearms. They're way more bent.
You took out collars, yes?
Old 11-03-2010, 05:33 PM   #13
wh0aitznic0
Talking about the rears. The front's I'm satisfied with.
Can't droop PBM's, dudes. It's designed really short unlike Megans which are long. The bottom bracket ends where the collars for the spring start and if you remove a collar, the bracket bottoms out at the housing. Definitely maxed out.
<3
Old 11-03-2010, 05:46 PM   #14
lflkajfj12123
That's balls. Guess you should have bought stance
Old 11-03-2010, 05:46 PM   #15
PoorMans180SX
Driftworks knuckles.
Bolt on, no modifying strut towers.
Instantly 1.6 inches lower. Improved suspension geometry.
It's a win-win.
Old 11-03-2010, 05:51 PM   #16
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
You could get shorter springs.
However, the ride height looks awesome in the picture you posted. Personally I would just go back to the -5° camber, because I think the -1° positive-looking rear camber that is so popular in drifting nowadays looks ugly.
I am all about the 2001 Kogouchi dropped-from-a-crane look.
http://www.youtube.com/watch?v=44LifXsVUSE
Old 11-03-2010, 05:51 PM   #17
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
HAHA that is the funniest thing Ive read in a while.
and bro, my cars so low.. i lay frame and lift my wheels off the ground.
HS13KLS is offline   Reply With Quote
Old 11-03-2010, 05:56 PM   #18
CleanAndLegit
Trader Rating: (55)
lmfao that made me do this
ahaha and to op i like how your car was
im going for that low possibly lower in rear my exhaust is about 1 and half fingers from the floor i need better exhaust clearance ):
Old 11-03-2010, 05:58 PM   #19
PoorMans180SX
Jealous much?
Old 11-03-2010, 06:07 PM   #20
Weedm
Weedm's Avatar
ah i see. cant droop pbm's. shit. lol.
and did you mean when you added positive camber, the rear raised up a bit? I went from -5 camber to -1 and my rear raised about 1/2 inch or so.
Old 11-03-2010, 06:18 PM   #21
Def
Shorter springs? It's not like you need/can use the suspension travel you have now.
DEFSPORT
Old 11-03-2010, 06:23 PM   #22
RurouniMidnight
RurouniMidnight's Avatar
RurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to all
I'd say get subframe risers notch out above the ruca so they won't hit, and pbm bent toe arms. Also why do you want -1 camber? id only try for that with serious track car maybe a nice mediate halfway point between -5 and -1 that you can work with.
http://nightparade.wordpress.com/
Join in on instagram @nightparade
RurouniMidnight is offline   Reply With Quote
Old 11-03-2010, 06:23 PM   #23
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
doesnt pbm sell a shorter spring for there coils?
joshchewuhh is offline   Reply With Quote
Old 11-03-2010, 06:28 PM   #24
fckillerbee
fckillerbee's Avatar
wait...you removed camber....and your car sits higher? why does that not make sense....if anything...it would sit flatter on the tire. Ever notice how your car lifts when you turn...its cause camber causes it to.
get a smaller tire. go 35 series. 215 35 dropped my car about half an inch.
I don't think the risers will lower your car. they just fix geometry. I have not researched driftwork knuckles on if they do lower your car more. maybe visit their site.
i'm running stance coils with 18's on my s14, and my fender and wheel are about 5mm apart. with -1.7 degrees camber.
below with -6 degrees camber. maxed out stance.
didn't change any heighth....camber now sits at 1.7 degrees. Notice how much lower the rear skirt is.
if I add more camber...that only brings the rim closer to the fender, and the car higher off the ground.
think of a box. what happens with you add camber to a box that is at zero degrees...better yet, grab a stack of post its, and lay it on one side. when you rotate it (add - camber) it gets taller. as simple as I can make it.
just get a smaller diameter tire. with the understanding that you want the car lower, and not the wheel closer to the fender. cause those are actually two different things.
Old 11-03-2010, 06:29 PM   #25
zerooath
98 Kouki Slicktop. Tip Dealer!
zerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to allzerooath is a name known to all
Send a message via AIM to zerooath
Just cut the coils on your already low coilovers since handling and functionality obviously isnt what your going for.
zerooath is offline   Reply With Quote
Old 11-03-2010, 06:39 PM   #26
PoorMans180SX
Risers lower the rear by 15mm. I've used them.
Driftworks knuckles do lower the car. That's their whole point.
Old 11-03-2010, 06:39 PM   #27
Weedm
Weedm's Avatar
I didnt think so either until I did it and measured my exhaust clearance. it went from 1.5 inch clearance to almost 2 inches..
perhaps it has to do with the tire as well. maybe if the tire compound or tire pressure is too soft or low, when the tire sits at an angle with negative camber, the weight of the car mushes it down. i dunno.
Old 11-03-2010, 06:44 PM   #28
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
get them switches!
airhead is offline   Reply With Quote
Old 11-03-2010, 06:53 PM   #29
Martino
Martino's Avatar
Martino is an unknown quantity at this point
PM Mark@UNION
Username: .white240.
IG: @vsMARTINO
Martino is offline   Reply With Quote
Old 11-03-2010, 06:58 PM   #30
chiboy002
shorter springs
also, guys, wtf does dropping mean/ how do you do it?
street dancer.
GLEAM
