Old 11-23-2010, 09:05 PM   #1
Genex626
Genex626 is an unknown quantity at this point
KA s13 starting issue and black smoke
Ok so here is the deal I recently got a s13 with a KADE and the car was running a bit rich drove it home and it ran strong just had lots of black smoke .so in the pass couple days I been trying to get the car to start for some reason it just turns over but doesn't start .the only way to start it is by spraying brake cleaner in the throttle body ... Now the thinks I have check and change are
Fuel filter and replace it
I check maf
Did full tune up
now I think it might be the fuel pump or the injectors what do u guys think also when the car would idle it would shake a little ...
Genex626 is offline   Reply With Quote
Old 11-23-2010, 09:09 PM   #2
Sileighty_85
Sileighty_85's Avatar
probably fuel injectors
check them per FSM
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-23-2010, 09:15 PM   #3
Genex626
s14
FSM??? What's that
Old 11-23-2010, 09:24 PM   #4
blktopsr20
blktopsr20's Avatar
Trader Rating: (83)
blktopsr20 is an unknown quantity at this point
Feedback Score: 83 reviews
Originally Posted by Genex626 View Post
FSM??? What's that
you kidding right? I fell of my chair laughing. thanks i needed that
JPR MOTORS partsforsell.com
blktopsr20 is offline   Reply With Quote
Old 11-23-2010, 09:27 PM   #5
Sileighty_85
Google
"240SX KA24DE FSM"
後輪駆動車1番
1986 SR86 - 200ish
Old 11-23-2010, 09:30 PM   #6
Genex626
For real lol I feel stupid not knowing
Old 12-01-2010, 02:14 AM   #7
Genex626
Still have the problem
Old 12-01-2010, 01:34 PM   #8
mike fonseca
mike fonseca's Avatar
Trader Rating: (43)
mike fonseca is an unknown quantity at this point
Feedback Score: 43 reviews
Sell it lol
mike!
mike fonseca is offline   Reply With Quote
Old 12-04-2010, 12:10 AM   #9
idlafie
idlafie's Avatar
FSM = Factory Service Manual.
Use the SEARCH function here on Zilvia to find a webpage that has a Factory Service Manual for you to download & read. Find the appropriate FSM for your model year car.
Your running rich issues could be due to several reasons: 1). Your fuel pressure regulator is NOT working or not getting vacuum 2). You may have a bad or leaky fuel injector 3). You may have a bad Engine Coolant Temperature Sensor, 4). You may have a bad Oxygen sensor or 5). Whomever tuned up your car, may have set the Idle too high allowing too much fuel into your combustion chamber.
All these items should be checked following the directions / service procedures listed in the Factory Service Manual. Once you get everything checked out & tuned to factory setting, you should have been able to solve whatever your problem may be. You may also want to check your vacuum lines & intake piping for cracking & tears. You should NOT spray brake cleaner into your throttle body. ONLY use carb cleaner OR throttle body cleaner.
If none of this helps, use your Factory Service Manual to put your Engine Control Unit, (ECU) into Diagnostic Mode & see what Diagnostic Trouble Codes your ECU kicks out
Anyhow, let us know what happens after you check everything. Hope this helps....
ID
Old 12-04-2010, 12:12 AM   #10
idlafie
idlafie's Avatar
PS:
You shouldn't.....a lot of people here on Zilvia started out the same way you did....not knowing a thing. But they've learned over time....just like you will.
ID
Old 12-04-2010, 12:28 AM   #11
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
Here, Let me google that for you
Tantwoforty is offline   Reply With Quote
Old 12-04-2010, 12:36 AM   #12
idlafie
idlafie's Avatar
Originally Posted by Tantwoforty View Post
HAHAHAH....ROTFLMAO!!!..HAHAHAHAH....
....Tan...you're such a comedian!!!...hahahaha
ID
Old 12-04-2010, 12:46 AM   #13
drift213
drift213's Avatar
drift213 is an unknown quantity at this point
dude you have flooding problem.. check if your FPR is good
LOTS OF SR20,ka24de,s13 goodies for sale check my threds
drift213 is offline   Reply With Quote
