12-07-2010, 03:46 PM | #1 |
Parts Shop MAX ~ ORIGINAL TIE RODS ~ In Stock! FREE shipping, order direct in thread!
Introducing: Parts Shop MAX original TIE RODS! You can buy stuff and get live shipping quotes right here in this thread! Simply click the blue add to cart link to check it out. VIEW CART Long and strong! This inner tie rod was created with large diameter, extra long length, and built in 1pc. 7mm angle spacers! The extra length is a must for our super angle kit modded knuckles or for customers widening the track width in front with aftermarket lower control arms. You can still use them with all OEM parts but you have to cut about 3/4" of the threads off. This makes the multi piece design of the Ikeya Formula rods we used to sell is just not necessary. Since it is a one piece design, we are able to give a smoking price on these. We will also sell matching OEM style strengthened ends just like we have always recommended using (SAK modded knuckles dont need bumpsteer spacers found on all the aftermarket outers) Max original tie rods are much stronger than OEM because of the increased diameter however in the case of a collision, we have you covered because our special steel alloy is factory tested to bend 180 degrees without breaking! Although the steering rack angle spacers are built in, and give enough angle without modded knuckles to over center, the thread on the rack end is the same length as other tie rods made for slip on spacers. In other words, you get the same steering angle as other inner tie rods with 7mm slip on spacers like Ikeya, but you have more thread engagement inside the rack. Optionally if you have a mod that moves the rack forward to prevent over centering there is room to stack on additional angle spacers. In the MAX original design we have moved the hex adjuster away from the center of the rod to a larger diameter area closer to the ball joint. We did that because we found that in a crash situation, the energy focuses on the sharp edges of the hex adjuster causing a crack or a break, but on the MAX tie rod it can absorb and distribute the energy more evenly to prevent failure. The diameter is only compatible with S14 outer tie rods (any brand or OEM is OK) but S13 rod ends are too thin and should be upgraded. The rack threads are the same weather its S13 or S14. Price is $75 per pair of MAX inner tie rods with free shipping world wide. Limited time introductary offer, no coupon code needed. New stock has just arrived! Limited lifetime warranty. CLICK HERE TO ADD TO CART & ORDER ONLINE Here are some pictures of the Inner tie rods installed on my car and attached to our roll center modded Super Angle Knuckles. VIEW CART
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 12-10-2010 at 01:19 PM.. |
12-07-2010, 05:13 PM | #3 |
me gusta pero no tengo dinero horita... ffffffuuuuuuuuuu!!
lol translate that bitch! Are you guys going to run something like cheap or free thread slimming? I have a hack saw at my house and i would not feel comfortable using that to hack threads lol. LOOKS GOOD AND IM JEALOUS
street dancer. GLEAM |
12-07-2010, 07:18 PM | #6 | ||
This is just about the cheapest mod out there so you are in luck, this is 50% less than the Ikea Formula rods we used to sell, and about the same price as Moog so with the free shipping its quite an amazing deal IMO you can select in the shopping cart two options: ~ Leave these long so I can run Super Angle Knuckles or wider lower control arms or ~ Please cut them to OEM length because I am never modding my knuckles or LCA's there is no additional charge if you wuss out.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
12-07-2010, 07:34 PM | #8 |
thanks for posting the pic !
12-07-2010, 08:04 PM | #10 |
We're trying to release it in February, wish us luck on that goal!
12-07-2010, 09:10 PM | #11 |
12-07-2010, 09:32 PM | #12 |
I have these Inner Tie Rods for S14 on a stock control arm. Make sure you cut & grind about 1/2" off the threads or it will never be centered and unable to get alignment.
12-07-2010, 09:44 PM | #13 |
Souljah, It's worth the wait because there is a bunch of stuff we have improved upon since the prototype.
12-09-2010, 09:32 PM | #15 |
I know Dan lol I have new coilovers want to slam my car already but until I have the adjustable control arms to correct my alignment, bumpsteer, and roll center haha
12-10-2010, 01:20 PM | #18 |
There is a limited lifetime warranty on this part.
12-15-2010, 06:14 AM | #19 |
I love the new design and product!
Looks like I have to add these to the PSM collection on the S13 when I come back in Feb! lets go to the track and test them out together! -Steve
Tsuiso.Style @ Instagram |
12-30-2010, 04:17 PM | #22 |
POWERED BY MAX: Forums
see the link for pictures, its OEM style since our super angle kit already spaces down the tie rod end. Also they last longer than ends with the bearing exposed. those are not released yet.
01-01-2011, 04:39 PM | #23 |
Wish these were out when I replaced my tie rods, would have bought them for sure. Good price, amazing guys and amazing products. +1 for PBM can't wait til spring to order full multi-link from you guys to go with these beautiful coils I got from you that I sadly have sitting on my desk to stare at and help winter go by faster. :P
01-10-2011, 03:39 PM | #26 | |
01-10-2011, 07:35 PM | #27 |
orderd these a couple days ago, waiting for em to come in. +1 for affordable tie rods with free shipping! everyone should take advantage of this offer
1992 Nissan 240sx Project |
01-26-2011, 03:41 PM | #28 |
there is too many [free] requests for shortening the tie rods, so we are now charging $15 for the labor to cut the length.
02-01-2011, 04:01 PM | #29 |
Sold out - We'll have more in march.
03-20-2011, 09:43 PM | #30 |
I have a set of the PBM tie rods paired with the Tein outers. I also have one of these steering spacers http://zilvia.net/f/suspension/36731...new-price.html. I had to cut about an inch off the PBM tie rods and after instaling and centering the rack spacer I have ran out of threads can i have the inners machined with more threads or should i just remove the rack spacer? I was able to set the toe before I instaled the spacer but now both sides are toed-in a ton.
