Old 12-14-2010, 11:24 AM   #1
Dream240
Dream240's Avatar
Driver's side window backwards
Hey guys, a wierd one for you.
I had my driver's window motor take a crap, so I bought a used one off ebay. Auction said it was a driver's side motor.
So I got it yesterday, pulled the door apart, removed the glass, motor, and power window framing. Removed the bad motor and bolted the new one up (it did bolt to the framing no problems). Then I proceed to test it and the damn thing is backwards!
The down button makes it go up and the up button makes the window go down. So either my car is slowly transitioning into backwards land or I've got a messed up motor.
Also, I took the door harness wires and reversed them to the motor, and no luck. What gives? Is this a passenger side motor, would it even bolt up to the driver's door? Never had this problem before.
The guy I bought it from is telling me to switch the wires coming from the motor, but I don't think that would matter since I already tried switching the wires coming from the door harness with the same backwards result.
Any help?
Old 12-14-2010, 11:35 AM   #2
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
When i bought a re-manufactured motor from O'Reillys it came with instructions that said if you experienced this very same problem after installation, you should reverse the wires and it will work perfectly fine. It's bizarre that swapping the wires isnt changing the direction that the motor spins.
Old 12-14-2010, 12:10 PM   #3
Dream240
Dream240's Avatar
I'll try taking both connectors off and mess with the wire connections to see if I can get it to go the right direction.
Thanks.
Old 12-14-2010, 02:45 PM   #4
driftn_silvia
driftn_silvia's Avatar
driftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to alldriftn_silvia is a name known to all
was it a nissan window motor?
driftn_silvia is offline   Reply With Quote
Old 12-15-2010, 09:33 AM   #5
Dream240
Dream240's Avatar
Yeah, it's a used factory motor from an S14.
I didnt get a chance to mess with it last night, tonight i'll do the wire thing.
Old 12-15-2010, 09:46 AM   #6
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
it's most likely backwards wires.
SW Fab
shiftdrift is offline   Reply With Quote
Old 12-17-2010, 11:31 AM   #7
Dream240
Dream240's Avatar
Yep, that was it. I just had the wires wrong. It was late and I was impatient.
Problem solved.
