Old 12-18-2010, 04:51 AM   #1
newlovekid
newlovekid's Avatar
Trader Rating: (43)
newlovekid is an unknown quantity at this point
Feedback Score: 43 reviews
s13 silvia triple projector low beams
what do i need to buy for this to all work out?
it has nothing... no bulb or adaptor for the bulb. is it hard to find?
newlovekid is offline   Reply With Quote
Old 12-18-2010, 05:19 AM   #2
Sileighty_85
Sileighty_85's Avatar
What do you mean adapter?
looks like your just missing the Rubber weather boot
The harness looks like it there just missing a wire (a red one) on the female plug
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-18-2010, 08:12 AM   #3
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
not to jack you thread, but what beam is that? i installed mine and the middle one and fog are operrational, but the outer ones dont work i try to turn on hi beam and they still dont work so im assuming those are my hi's?
S-Nation S13 is offline   Reply With Quote
Old 12-18-2010, 09:15 AM   #4
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
there is a bulb holder there for the H1 bulb.....idk where you would find that, maybe check classified here or yaj
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 12-18-2010, 09:28 AM   #5
SaNTi
SaNTi's Avatar
SaNTi is an unknown quantity at this point
That's the low beam.
SaNTi is offline   Reply With Quote
Old 12-18-2010, 09:45 AM   #6
ROOSEY
ROOSEY is an unknown quantity at this point
^+1. correct me if im wrong but i believe all or most cars have the low beams on the outside and highs on the inside.
ROOSEY is offline   Reply With Quote
Old 12-18-2010, 10:04 AM   #7
ILLES13
ILLES13's Avatar
Trader Rating: (41)
ILLES13 is an unknown quantity at this point
Feedback Score: 41 reviews
Sorry to thread jack, but i was wondering. I have the dual projectors, and i'm running 4300k hid's in them. I have the most horrible output ever, even after trying to adjust them. Is that just how the projectors are? what gives
ILLES13 is offline   Reply With Quote
Old 12-18-2010, 10:24 AM   #8
srstan
srstan's Avatar
srstan is an unknown quantity at this point
yup all silvia headlights are shitty....Clear corners has a conversion kit that you can buy to make the light output correct.
srstan is offline   Reply With Quote
Old 12-18-2010, 12:39 PM   #9
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
those are my old lights, and yes its a little rubber thing, i found them in my driveway yesterday. OP call me and I will give them to you
jacobs13 is offline   Reply With Quote
Old 12-18-2010, 12:42 PM   #10
kevmeistah21
kevmeistah21's Avatar
Trader Rating: (68)
kevmeistah21 is an unknown quantity at this point
Feedback Score: 68 reviews
Send a message via AIM to kevmeistah21
all silvia light outputs suck dick..
cheaper to go with tsx projectors.
Late Night Crew... #02 <3
Bought anything from me? Please leave me a review!
http://zilvia.net/f/private-sellers/...meistah21.html
kevmeistah21 is offline   Reply With Quote
Old 12-18-2010, 12:55 PM   #11
newlovekid
newlovekid's Avatar
Trader Rating: (43)
the female plug goes onto the low beams and the male plug connects to the light switch on your car.
middle light is high beam and the outter light is the low beam.. its all plug and play if everything is there.. but im missing the low beam so its not for me ha
so if i buy HID's i dont have to worry about that adaptor?
Old 12-18-2010, 12:58 PM   #12
S-Nation S13
Trader Rating: (92)
so the middle lights are hi beam and the outer lights are the lows? wth, when i switch to normal head lights the middle lighs up, when i switch to hi the mid come off and nothing lights up so i thought my high were blown out ?
Old 12-18-2010, 01:05 PM   #13
Sileighty_85
Outsides are Low's middles are High's
The Male & female plug together for the Low's and High's, Fog Lights use their own harness.
I show in here how the plug should be wired up (there is a bonus wire up for the Q's Lights)
http://zilvia.net/f/tech-talk/276805...l-wire-up.html
後輪駆動車1番
1986 SR86 - 200ish
Old 12-18-2010, 01:06 PM   #14
newlovekid
newlovekid's Avatar
Trader Rating: (43)
well idk maybe your headlights are like that.. when i put my low beams i get nothing, but when i put it on high beams it lights up in the middle
Old 12-18-2010, 01:10 PM   #15
Sileighty_85
somthing is Jacked up in your wiring then, Maybe your Head Light Stalk switch needs to be replaced.
All S13 Silvia lights use the same config. (outside Low's, Middle's High)
Low's
後輪駆動車1番
1986 SR86 - 200ish
Old 12-18-2010, 01:15 PM   #16
newlovekid
newlovekid's Avatar
Trader Rating: (43)
no my lights are right ha my high beams are middle.. hey if i replace Head Light Stalk switch would it fix my high beams cause only my passenger side light works when highs are on.. its been like that even when i had my pop up lights
Old 12-18-2010, 01:19 PM   #17
S-Nation S13
Trader Rating: (92)
wth? i thought it was plug and play hm....from usdm to triple project with the exception of the fogs
Old 12-18-2010, 01:23 PM   #18
Sileighty_85
Sounds like a Stalk issue.
I cant remember, My Silvia harness was Cut so that why I had to solder mine and made that write up, JIC someone else had this issue
後輪駆動車1番
1986 SR86 - 200ish
Old 12-18-2010, 06:11 PM   #19
S-Nation S13
Trader Rating: (92)
i have a set of h4 bulbs ill plug it into the harness if my harness is legit, lo and hi should work fine if it does, then i guess its my silvia lights that are messed up
Old 12-18-2010, 08:42 PM   #20
S-Nation S13
Trader Rating: (92)
sileighty 85 what bulbs are you using ? for all three please
Old 12-19-2010, 01:10 AM   #21
S-Nation S13
Trader Rating: (92)
my lights are now all operational, proper. so with that being said, how do you adjust the beams itself?
Old 12-19-2010, 08:45 AM   #22
S-Nation S13
Trader Rating: (92)
to fig outthis problem here you go your missing the black piece, its the bulb holder changes the 1 prong h1 into a 3 prong h1
Old 12-19-2010, 09:39 AM   #23
Sileighty_85
Im using whatever the headlights use stock
Its been awhile but i think its
LB- H3C
HB- H3
Fog- H3C
後輪駆動車1番
1986 SR86 - 200ish
Old 12-19-2010, 10:08 AM   #24
SaNTi
SaNTi's Avatar
LB- H3C
HB- H3
Fog- H3C
Low beams are H1.
Old 12-19-2010, 02:20 PM   #25
Sileighty_85
Originally Posted by SaNTi View Post
Low beams are H1.
That right, I forgot hes got K's Lights.
I got Q's so mine uses H3C
後輪駆動車1番
1986 SR86 - 200ish
Old 12-19-2010, 02:42 PM   #26
newlovekid
newlovekid's Avatar
Trader Rating: (43)
alright i got the adaptor for it but it has no 3 prong.. its empty like the previous used hid soo im forced to get hids now
Old 12-20-2010, 08:44 AM   #27
S-Nation S13
Trader Rating: (92)
if you go to the link on the bottom of the pic, they did an hid install so if you need help go there
Old 12-20-2010, 08:46 AM   #28
S-Nation S13
Trader Rating: (92)
thanks sil 85, i inspected mine and i used the same lights as you except for the low lol
Old 12-22-2010, 10:46 PM   #29
aalbert240
aalbert240's Avatar
aalbert240 is an unknown quantity at this point
can you send me the web page address im having trouble finding the hid install page thanks
aalbert240 is offline   Reply With Quote
Old 12-22-2010, 11:44 PM   #30
S-Nation S13
Trader Rating: (92)
S13 Silvia Hid H1 Headlight Conversion With Pics - Boostcruising
dont know if the install is product specific but here you go
