Old 12-17-2010, 11:04 PM   #1
dorf26
dorf26 is an unknown quantity at this point
Ka24de swap help
I did a ka24de swap and i cant get any spark. iv tried two different coils and two different distributers but no change. also have had a few different harnesses. any and all opinions will be very helpful.
dorf26 is offline   Reply With Quote
Old 12-17-2010, 11:07 PM   #2
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
More info! What car is it going into. What motor did the car have originally. Etc...
mxexux is offline   Reply With Quote
Old 12-20-2010, 07:56 PM   #3
dorf26
alright. i bought a s13 shell. it had a 5 spd in it originally. i bought a freshly rebuilt ka24de with trans and everything but a harness. i bought a harness. found out later it was all cut up. bought a new one, that solved some issues but still no spark. got a distributor out of another ka, still no spark. tried different coil, still no spark, everything is grounded, everything is plugged in. i honestly dont know what else to check.
Old 12-21-2010, 01:01 AM   #4
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
Use a voltmeter and measure what volts you have at the coil, ignition, and at the dizzy. Also what did you do as far as the engine>dash plug? Did you just connect it? or cut and splice wires? What year car/ dash harness is used and what year motor?
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 12-21-2010, 03:14 AM   #5
dorf26
cut and matched wires car is 91 motor is like 91-92.
Old 12-21-2010, 03:45 AM   #6
eddieflo
eddieflo's Avatar
eddieflo is an unknown quantity at this point
Send a message via Yahoo to eddieflo
grounds????
Wastelandfresh.tumblr.com & soundcloud.com/eddieflo
eddieflo is offline   Reply With Quote
Old 12-21-2010, 05:55 PM   #7
modulation
modulation is an unknown quantity at this point
You know you have no spark cause you've set a plug on the valve-cover or shock strut top and hooked a wire too it and you're seeing no spark right? (You aren't just guessing its no spark and not fuel right?)
As people said check your grounds. There is one that connects to the firewall in the middle top back of the engine. Also is your coil connected to the chassis, that is ground for it.
modulation is offline   Reply With Quote
Old 12-21-2010, 11:35 PM   #8
dorf26
yes i know how to check for spark.. and yes i am getting fuel. also everything is grounded.
