![]() Join Date: Dec 2010
![]() Feedback Score: 9 reviews
Spacers
Hey guys Im gonna be using This Kit on my 92 coupe with stock fenders and 17x7 wheels what size spacer should I run for flush appearance.
![]() Join Date: Jun 2008
jesus, ideally a x9+15 is imo the perfect wheel size for an s13 on stock body. (i know some of the fitment gurus will disagree but from what i have seen it looks pretty good and requires just a roll and pull)...sooooo with that being said you need (again in my humble opinion in regards to fitment) a 25mm or a 30mm i would just spend the 100 bucks on the psm kit as you can run either size with it.
#11 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Honestly, you'll need like 50mm of spacer... I'm running an x9+22 on my s14, which has a little bit of a wider fender, and I still want 20mm spacers to make it +2 effective...
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#14 |
![]() Join Date: Jan 2009
id say about 70mm spacers with a 30mm over fender, and possible a good stretch like, a 145/35/17...
if you want to be illist that is...
RIGHTWHEELDRIVE.com
#15 |
![]() Join Date: May 2008
![]() Feedback Score: 10 reviews
for the OP, here is 9.5+15 on my stock bodied 13...
![]() not the best pic, but it gives you an idea. its pretty much flush, little tuck/poke. To achive this look (if thats what you want/going for) you'll need 57mm more. so i guess a 50mm spacer. http://www.1010tires.com/wheeloffsetcalculator.asp <---- for all your wheel offset calculation needs/questions |
#18 |
I like the kit, I already ordered it. Also like the wheels and they are already installed :/..ill try them both out for a while and see how i like them, if in a few months im not happy ill make a change.
#19 | |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
S14 Drift junkE are those staggard or just 9.5 all around?
#21 |
Since you have already ordered the spacer kit and have the wheels, just drive it as is for a bit. See how the fitment is with the alignment you want, then save for rims that will have the offset you want to no longer need spacers. Use the calculator to see how the rim width and offset will affect clearance.
I punch b*tches for gold nuggets... |
