#31 |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
Get a mechanic u ungrateful person! u said u are not 21 so u should be able to afford a mechanic. It seems like u are the one guessing!! I hate people like u . U try to help. and then they give u shit, like if u know. Sorry for shit threading though...
NEED Bolt kits for your car? |
#32 | |
![]() Join Date: Mar 2007
Obliterate |
#33 | |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
#34 | |
Trader Rating: (81)
![]() I am not ungrateful to those that offer LEGIT info. Like I mentioned before, anyone can come into this thread saying, check your MAF, check your timing, blah blah. Alot of this shit is already done with and check/verified. I only post a thread when I'm stumped (hence the low post count) as in this instance.
#35 | |
Obliterate |
#36 | |
If everything has already been tested and your so awesome and everything Is perfect. then dont ask questions. I really do wish u never fix this problem for being such an asshole douche bag. I hope It gets even slower. 28 year old dumbass
Obliterate |
#37 | |
Trader Rating: (82)
Thank you... Exactly...
#39 | |
We would have loved that but he's too much of a dumbass to comprehend what we are telling him. He keeps saying everything is perfectly amazing.
Obliterate |
#40 | |
Trader Rating: (81)
Oh by the way, timing is good, TPS is good. Although my TPS was maxed out, my PFC read 0.45V throttle closed and 4V fully open. Just to be sure I swapped it out with 2 others I had and both would not even go above 4.1V...and my TB is a confirmed SRdet one. I remember someone saying fully open should be 4.8-5V? FSM states approx 4V... guess all left is the CTS to check. ![]()
#41 | |
![]() Join Date: Mar 2006
The list of things you said COULD be the issue is in no way comprehensive. It is only a list of the most likely issues. The fact the problem goes away when the car warms up rules out the TPS, which you have been pushing for so hard. Settle down.
Daily driven |
#42 |
![]() Join Date: Sep 2005
How about getting the car warmed up and disconnecting the coolant temp sensor?
You think the outcome would be different? I know with my software I can tell the ecu, in active test mode what the temperature is and it will respond to that condition. PFC not so advanced? lol. Why is it taking so long to eliminate both CTS and TPS anyway?
#43 |
Trader Rating: (81)
TPS has already been confirmed good.
CTS is good b/c my readings from PFC commander match up to what my Defi guage reads +/- 2 degrees...unless theres another function the CTS performs? Timing has been confirmed by re-stabbing CAS and checking timing with a gun. going to change out my plugs/coilpacks this weekend. Putting in Irway iridiums and Splitfires, see what that does...
#44 |
Guest
Posts: n/a
its like a retard festival here
the problem is your car....... its a piece of shit. solution? change it for one that isnt a piece of shit. |
#45 |
![]() Join Date: Nov 2010
this is simple.. u need FINE TUNING.. when u run big cams such as 272. u always get that delay when the car is warming up... i had the same problem on my 500hp sr20det... i just let it warm up and it doest bother me..
#46 | |
Trader Rating: (81)
My low end might be just stupid rich or something. However, theres never any smoke.
#47 | |
Trader Rating: (81)
#48 | |
I think that the IACV has it's own internal coolant temp sensor that is used to control high idle during startup, right? (why else would coolant be run to the IACV???). Anyway, I am wondering if on your car (and mine), that sensor is semi-shot and causes suckiness...
Daily driven |
#49 |
I've run with no IACV coolant lines and the symptoms OP/TS describes did not occur.
I've tuned multiple setups over the summer, so i figured I'd leave those lines looped and during summer months there was no difference in idle or throttle response. As soon as the weather changed, I could not idle for shit. It would go through the normal process of warming and idling, then once at operating temp it would idle at 1500rpm or higher, max 1800rpm. I could only drop it about 300rpm. I've only blipped the throttled during the high idle rpm, it responded normal. I knew exactly what the problem was, so i ran coolant lines immediately! And even though my first attempt was leaking it idled correctly. It happened around thanksgiving this year. Along with my other, annual 240sx problems like, Auto seat belt failure, and driver side auto window failure. Last year it was also headlights, but not this year! FIXED HEADLIGHTS FOR THE WIN! Then again every car, cannot respond the same to every situation, tune, diagnosis etc. That would make it too easy.
#50 | |
Daily driven |
#51 |
What am I really trying to say? Hmmmmmmm, is that there are common symptoms for part failures. The common symptom for not having the coolant lines hooked up to the IACV is the high idle, that of which is uncontrollable in cold weather. (correct)
I also made a comment about annual, yearly problems, related to my 240sx. Of which i noticed other members having.
