#1 | |
It's Always Broken.
![]() Join Date: Feb 2010
![]() Feedback Score: 14 reviews
How to make my car not boost?
I have a T25 setup on my KA24DE, and I need it to stay out of boost. I don't have any fuel management as of yet and I don't want it to run lean. Don't ask, I'm waiting for shit to get shipped to my door and it's taking forever cause winter storms on the east coast.
Anyway, can I disconnect my wastegate actuator arm? Hopefully that will cause it to stay out of boost and run like normal?
#4 | |
It's Always Broken.
Yeah, it hasn't been driven the last 5 days. No worries. I was just curious if that was possible.
Just take the wastegate actuator off. Should work.
Like Me on FaceBook ![]() |
#9 | |
It's Always Broken.
I can't just get a boost gauge and observe the boost lol, I don't want it boosting at all. It misses at idle and bogs under normal driving, since it doesn't have enough fuel I'm guessing, so I'm just trying to disable it until I can figure it out.
@ steve shadows, I guess I will try that. Oh, and tell me if this sounds right people: KA-T with T25, FMIC, etc etc etc, but with no fuel management. When floored it goes vrooooom, then boost hits and it goes blahhhh, and it stutters and won't go into boost. I'm guessing it's because it has more air than it used to, and now it needs more fuel than it used to have as well. So when I go into boost and it stutters, goes blah, etc, it's cause it's going lean. Correct? So hopefully when my shit gets here, it'll fix this problem.
![]() Join Date: Apr 2007
Sounds like something else is wrong. The engine wouldn't be getting "more air than it's used to" at idle because of a turbocharger. And if you consider putting around under boost 'normal driving', then normal driving with all factory running gear and a small turbocharger won't make it bog. You have other problems, most definitely.
#11 | |
It's Always Broken.
It had no problems before boost, so maybe a possible boost leak???
The PERFECT way to explain it is that when it goes into boost at FULL throttle it's like it's hitting the speed limiter. It just falls on it's face
#12 | |
![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
![]() Join Date: Jun 2006
I agree with mikerbiker, you def have other problems, yes check for a boost leak, your car will run lean before book, then rich while in boost (I believe that is how it is).
If you want no booost, I guess there are couple of ways you can do it. 1. Make the arm on the WG actuator a lot longer (you'll have to mod it, but its pretty easy, just do a search, or you can do what I did (because my WGA stopped working and I was kitting 17psi). I got the HKS adjustable, when I turned it up all the way (full length), I would make like 2psi at FULL THROTTLE at 6000RPM,, I didn't realize how SLOW and SR without boost is. 2. You can get real extreme and just bypass the turbo all together and hook a tube from the make straight into your thottle body. You'll be completely without boost then. Though I would still put some kind of filter over the turbo (don't want crap getting sucked in) |
#14 | |
![]() Join Date: Sep 2005
For this 240 owner, it's probably the safest option period! ![]()
#15 | |
LOL, I didn't realized I left out MAF and was missing a few other things. I was caught in mid sentance in the middle of work when putting up the post. LOL After going back and reading mine I was like OOPS...lol.. Thanks for correcting it for me. |
#16 | |
If the flap door is open it shouldnt boost at all or maybe only 1-2 psi. The flap door having tension and being closed is what creates build up of exhaust pressure which creates boost on the compressor side. If you just take off the vacuum line to the actuator you are correct though gotta take the arm off the door, other than that it's a mechancal ssystem, you would have to remove the turbo to remove the possibilty of any positve pressure at all
#17 |
![]() Join Date: Jun 2003
Trader Rating: (130)
Disconnect the wastegate arm from the flapper. There should be a small c-clip connecting em. Voila, no boost.
#19 |
If you are running stock injectors, and running a blow-through setup (MAF sensor in front of the intake manifold or after the cooler) there is a way...
You could disconnect the cool side pipe from cooler to MAF leading to intake manifold. But I would not drive around like this for a long time unless you have a filter in front of MAF. Best bet is to wait for your parts to come in and get everything done right 1st time. |
#21 | |||
Disconnecting the wastegate actuator from the wastegate flapper (as described in the posts you're trying to discredit) will decrease boost, a lot. Quote:
#22 | |
Though this is all a lot of effort to run zero boost. Maybe best idea not to drive it, or put back on the OEM setup until all the stuff arrives. |
#23 | |
He's over thinking the idea, If there are no charge pipes connected, there would be no boost to build, "NO BOOST TO BUILD" even if the wastegate was still connected. again the compressor outlet to hot pipe would have to be connected in someway to the throttle body.
As long as the little T2 had oil and water it could run this way forever! Quote:
#24 | |
And if you "connected in some way" the "compressor outlet to hot pipe to the throttle body", wouldn't it be like normal? Sending compressed air from the compressor outlet to the throttle body? Were you high when you wrote that?
#25 |
I was answering the OP's initial question. No boost. Now regarding the spinning of the Turbo, if the wastegate was still connected or not, its going to spin. agree? never being able to make boost is the outcome. I don't really know what you're getting at. Disconnecting the flapper isn't going to stop the turbine from spinning uncontrollably. Either way is a no boost answer to his question.
And yeah, I'm a little tipsy and its a new years after after party. ![]() Sent from my T-Mobile myTouch 3G using Tapatalk
#26 |
False. The reason the flapper is pushed open by the wastegate actuator is to CONTROL the speed of the turbine/compressor. I'm sure the flapper will be pushed open at idle if it's not connected. Sure, the turbo will spin, but not enough to build any boost against the charge piping/intake tract.
#27 | |
Trader Rating: (40)
#28 |
He said 'uncontrollably'. The reason the wastegate is there is to 'control' the speed of the turbine/compressor. And the exahust flow isn't the only thing regulating the speed.
I've never disconnected my flapper from the actuator to see if it is open at idle, so I could be wrong. But it doesn't take much to swing 3 ounces of metal on a <1" fulcrum. I had a small T3 on a KA a long time ago, with the flapper assembly removed completely, and the turbo wasn't spinning at idle. I didn't drive it around like that to see how much boost it made in the upper RPM though. But I'm sure, positive, that unless I was using high throttle/high RPM, it wouldn't boost. Positively sure. If it's warm this weekend, I'll disconnect the actuator from the flapper on my SR, just to see, and report back my findings. ![]()
