Old 01-20-2004, 03:52 PM   #1
96s14kat
96s14kat is an unknown quantity at this point
Send a message via AIM to 96s14kat
ka-t dies when letting off throttle
my motor keeps dieing when im driving and its reved up and i put it in neutral or push in the clutch. ever since its been turbo'd its been doing this. my bov is recirculated so i know this is not the problem. someone suggested bumping my idle up a bit. any suggestions? it only seems to do it when its higher in the revs and i let off the gas and put it in neutral or push in the clutch. its also very hard to start after it dies.
96s14kat is offline   Reply With Quote
Old 01-20-2004, 04:14 PM   #2
charlie@justdrift
charlie@justdrift's Avatar
charlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond repute
Send a message via AIM to charlie@justdrift Send a message via Yahoo to charlie@justdrift
i had the same problem before... it turned out to be my maf sensor plug.
charlie@justdrift is offline   Reply With Quote
Old 01-20-2004, 04:22 PM   #3
96s14kat
was the plug bad or what? im running a hacked mafs right now.
Old 01-20-2004, 04:23 PM   #4
charlie@justdrift
no the maf wasn't bad... the plug was bad.
Old 01-20-2004, 04:58 PM   #5
96s14kat
so the peice where the wires come together that you plug into the mafs?
Old 01-20-2004, 11:02 PM   #6
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Actually I think most of us KAT's had this problem. I solved mine by turning up the idle adjust screw located near the firewall on the passenger side.
Check around for a picture.
BTW it'll still die if I rev it to like 6 and then immediately let off. You have to master the art of 'catching' the RPM's =D
Maeda is offline   Reply With Quote
Old 01-21-2004, 10:38 AM   #7
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I say it's proximity of the MAF to the turbo. JWT recommened 18" of pipe between the turbo and MAF, and my car would run like hell without that distance. Also, did you plumb the 1/4" tube and the 5/8" tube into the intake? The 5/8" to the right of the throttle body goes into the pressurized piping, and the 1/4" hose goes into the unpressurized, metered piping.
-Jeff
Whatup?
Old 01-21-2004, 11:29 AM   #8
96s14kat
does the 1/4 hose come from under the TB? i just pluged that on up. i have the valve cover breather hose, and the bov recirc. hose going to the intake before the turbo and thats it. and my mafs is like a foot or less from the turbo. its all very tight. i dont have room to move it farther away.
and yea ive heard of a few other kat's w/ this problem, it just gets annoying that i have to keep my foot on the gas a lot more. when you adjusted the idle did you disconect the tps sensor(i think thats what it is) and where did you set it at? thanks.
Old 01-21-2004, 12:24 PM   #9
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
take some pictures of your engine bay so we can see if you have all the right hoses hooked up.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 01-21-2004, 01:28 PM   #10
Maeda
Maeda's Avatar
-Jeff
That might be it as well but for me the idle adjust keeps it alive enough. Next time I cut pipe maybe i'll change that(my maf is about6 inches from the turbo).
Old 01-21-2004, 02:02 PM   #11
96s14kat
heres a few pics. im pretty sure i have the hoses right. ive got the crankcase breather and bov recirc. hose routed to the intake before the turbo and thats it. and i have the one hose coming out to the right of the TB routed to the pressurized piping(i read that jwt said to put it here.)
there was one other small hose, (like 1/4'') that used to go to my old intake before i had a turbo. it comes out somewhere under the TB. i just plugged it up.
Old 01-21-2004, 02:30 PM   #12
Jeff240sx
I hate you too...
Jeff240sx's Avatar
As I said before, the 1/4" tube goes before the turbo, after the MAF. And I'll put $5 that your problem is the placement of the MAF. You've got like 3" there.
-Jeff
Whatup?
Old 01-21-2004, 06:00 PM   #13
96s14kat
-Jeff
yep i agree w/ you there, but i have no room to move it anywhere else. the only place i could possibly relocate it to would be down behind my IC, but i dont know if that would be good because it would be sucking all the hot air that passes through the ic.
also, what does that 1/4'' tube do? i dont see how that little hose could make a difference. i was told just to cap it off.
Old 01-22-2004, 12:59 AM   #14
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
Jeff- Do you have that same problem with your KA-T?
I remember I had a problem like that but after I replaced battery and alternator everything was fine. But, it also only did it in the morning when I first take it out.
-Juan
240Stilo is offline   Reply With Quote
Old 01-22-2004, 08:42 AM   #15
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
I'm not sure if the S14 is set up the same as the S13, but in my S13 I have (or had) a resonator box that was under the original air-filter box (I believe its where the Injen cold air intake extension goes). Anyhow, could you refit the air filter down there, then put the MAF in the extreme corner of the engine bay (lower down to the right from where you have it currently?).
Just an idea.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 01-22-2004, 11:13 AM   #16
Evil S14
Evil S14 is an unknown quantity at this point
Send a message via AIM to Evil S14
same thing happened to my KA-t, turns out i had a vacuum leak.
*image exceeds forum limit*
-Moderation
Evil S14 is offline   Reply With Quote
Old 01-22-2004, 12:29 PM   #17
96s14kat
Just an idea.
-m
well that is where i have my smic mounted. i already thought about putting it down there but theres not much room behind the ic, plus i dont know if i should becuase it would be sucking all the hot air that passes through the ic.
Old 01-22-2004, 12:46 PM   #18
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
maybe try moving the coolant resivoir and cutting/ fitting the intake through there
AceInHole is offline   Reply With Quote
Old 01-22-2004, 09:41 PM   #19
Mr. Spool
Mr. Spool is an unknown quantity at this point
Ace where did you place your maf, I have seen them placed after the smic, before the throttle body and the second place is were he has is possitioned, right on the way into the turbo. I dont have all my turbo jarkin down, so I hope I described the places correctly. also would either of these two places affect the way the car runs.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 01-22-2004, 09:48 PM   #20
AceInHole
Autox Technician
AceInHole's Avatar
my MAF is as far away from the turbo as possible, before the turbo (right after the air filter).
Old 01-22-2004, 09:52 PM   #21
96s14kat
what you are talking about is the blow through type(where its located anywere in the pressurized piping), and the pull through type,(where it is before the turbo) they both do the same thing no matter where they are located(meter the amount of air going into the engine. some people mount them in the pressurized piping so they can put the bov before the mafs so they dont have to recirculate it. i didnt do it because i didnt want to have to worry about sealing the mafs w/ the ic piping.
Old 01-23-2004, 06:43 AM   #22
Mr. Spool
Thanks for the info. which way is more effective. could you possibly aleviate your proplems by making it a push through type. also what do you mean by selling the ic. I have a side mount.
96' SE Turbo'd
Old 01-23-2004, 10:51 PM   #23
96s14kat
i think either way would be just as effective. i might be able to fix my problems by doing that, but since im running a hacked mafs i want it to be easy to get to and take on and off. if you have the mafs after the turbo in the pressurized piping, you have to have it sealed good so it doest leak there.
