Old 01-20-2011, 04:22 PM   #1
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Mounting 180sx Type x sideskirts
I looked and looked for info but found nothing so please Dnt tell me to search if you want to help please do. I'm having trouble with the inside of the skirts of the would I have to drill holes on the bottom Panel of my car? That's what I'm Trying to avoid.
da_crew10 is offline   Reply With Quote
Old 01-20-2011, 04:41 PM   #2
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
Google
THANK ME LATER
As long as you're not a ham-fisted retard there shouldn't be a problem.
Psychomoongoose is offline   Reply With Quote
Old 01-20-2011, 04:55 PM   #3
da_crew10
da_crew10's Avatar
Originally Posted by Psychomoongoose View Post
Google
THANK ME LATER
Already did man . If u own a pair and mounted them help me out if not them
Move along.
Old 01-20-2011, 05:09 PM   #4
chiboy002
supposedly they have holes already there along the pinch point or w,e its called, i forgot
Most of the time theyre bent to shit on our cars, best bet is to drill holes or self tapping/sealing screws
street dancer.
GLEAM
Old 01-20-2011, 05:13 PM   #5
urquhartaw11
urquhartaw11 is an unknown quantity at this point
there should be a little metal thing coming off the sideskirt that can reach inside the car, and goes up under the plastic skid plate (whatever you call it) inside the door. thats about the best i can describe it man.
urquhartaw11 is offline   Reply With Quote
Old 01-20-2011, 05:39 PM   #6
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
yes there should be no need to drill anything, there shoul be metal tabs..unless it never came with it, then your pretty much at driling holes. technically you should be good if you got a good mount on your front fender and rear quater panel, if you also use 3m double sided tape, the strongest bond one, then your a ok no need to worry bout mounting the bottom.
S-Nation S13 is offline   Reply With Quote
Old 01-20-2011, 06:35 PM   #7
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
On mine, I used zipties to hold the two parts together, so I can mount it just at the ends like I would a regular one-piece skirt.
Old 01-20-2011, 09:53 PM   #8
da_crew10
da_crew10's Avatar
Hey u guys I appreciate the info ima get all my complete type x kit sanded down
And prepped for paint b4 I figure out how I'm
Going to mount them hopefully they go on easy and stay on!
