#1712 |
![]() Join Date: Apr 2007
Edit: FOR Mad-ass..
Just set up your car a little different then. I use 205/45/17F and 245/40/17R with my N/A KA. No more understeer, just less oversteer. Pretty sure Powers used 235/40/17F and 275/35/18R at Infineon this year. Pretty sure.
#1714 |
I have my car setup pretty durn good at the moment with the tire sizes, don't see anything wrong with them, just that I gotta prepare my car to accept the power of LS1 swap here soon and want to put down more tires then I am right now, at least rear camber wise. since I didn't even think about balancing out the tire width front to rear at all, this changes everything! lol
then again, GTO's stock come 235/40/18 all around, and that's LS2/400hp on tap, so I think 255 in the rear with almost no camber will do good!
#1715 |
Philosopher King
If you're concerned about grip and balance you may want to check out Nissan Road Racing Forums - Powered by vBulletin.
G O L D E N B E A R R E P U B L I C |
#1716 | |
![]() Join Date: Nov 2006
btw im running 255/40 all around on 17x9 +22 advan rgII's. 1.5* camber up front and 0.8* camber out back. Sorry, pic isnt the best angle =/ ![]() |
#1717 | |
#1718 |
Need help planning on getting 17" or 18" f9/r10, what would be a good offset and tire size for a s14 want alot of grip as im going to put in a 2jz.
s14 grip monster=2011-2012 |
#1719 |
#1720 |
![]() Join Date: Jun 2010
I would go with 18x9 up front in the +17 to 25 range. For rears would go 18x10 +25 to 35 This all depends on how much tire you want and your motorsport though. Obviously if you want 285's or some shit in the rear (drag oriented setup) you dont want to go with 18x10 +25 in the rear...That would require enough camber to lose effectiveness. However if your going for a grip/road course type oriented setup more camber would be acceptable and still remain useful. Last edited by Nick_04K; 01-23-2011 at 01:39 PM.. |
#1721 |
Philosopher King
LOL at rude 16 year old talking out of his ass.
#1722 |
^^^Man, seriously. Straight out his ass. Both setups can work though... His just isn't what I'd do. Do his setup if you're scared of rear fender work, I guess. You might get lucky if you go with his 17x9+25 up front and it just barely clears your coilovers, but probably not.
#1723 |
![]() Join Date: Dec 2010
![]() Feedback Score: 9 reviews
Ok I guess this is the best place to ask? So I am running 17x9 +12 F and 17x9.5 +12 R so here is my question are 235/40 and 255/45 good sizes to run on a stock bodied S13?
#1725 | |
Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch 255/45 is really tall. Try 255/40 on the rear. /suggestion
#1726 | |
#1727 | |
![]() Join Date: Jan 2004
#1728 | ||
Like I said, you might get lucky, if you picked a coilover that has more backspace than most. Don't run around telling folks that 17x9+30 will CERTAINLY clear coilovers, because in alot of case, it won't. But +20 certainly will. Quote:
#1729 |
The reason why i was asking is because i want something like J-rho's S13 those tires were massive and the car handled mint imo.
#1730 | |
RIMTUCK.com - Setup I think it looks great. But I think if you're gonna make statements like the one I just quoted, it might be helpful to the less informed if you clarified that you're running Koni+GC sleeves and not the typical off the shelf coilover. Just to keep miscommunication & misinformation down to a minimum. |
#1731 |
![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
whats up going with a new setup soon so wanted some input on tire sizing.. i'm going with 17x9 +20 f and 18x9.5 +15r.. im on kyb agx with tein s.techs( low enough for nyc daily driving) on an s14.. i was thinking to go with 235/40/17 in front and 255/35/18 in the rear.. what you guys think? good balance? if not open to suggestions..
#1732 | |
Talking out my ass? I sure wish you would elaborate on that. Seems how my statement was factual and pertinent.
And my statement was not rude...I just wanted him to know that a +20 on a 9j or 10j with the purposed tire sizes was going to need fender work and a decent amount of camber. Quote:
In most cases that setup will work! And it will be easier and most likely more effective than your purposed setup too, unless he's got a car capable of using the camber necessary to fit your setup. Which is doubtful. |
#1734 | |
Your proposed 17x9's for the front with offset between +17 to +25. Do you realize that my suggested +20 offset falls within that range? Do you also realize than going much higher than +20 in the front won't clear alot coilovers? Do you also realize that many ppl have been running 17x9+20 FN01RC's with 245/40 tires for YEARS now? From way earlier in the thread: 17x9+20(effective) with 255/40's fronts. Rears are 17x10+25 with 275/40's. Rolled and only slightly pulled. ![]() ![]() Does this camber look unneccessary or extreme? Not at all far off from my suggested 17x9+20 with 245/40's and 18x10+20 with 265/35's. His rears are 5mm less flush, but since the tire size I recommended was 10mm narrower and lower profile, should fit about the same. There is a reason why I gave very specific specs instead vague estimate with wide margins, like you. It's because the sizes I recommended are common to find and have been done before. And yes, you are a rude ass little kid. Last edited by simmode1; 01-23-2011 at 09:27 AM.. |
#1735 | |
***A 18x10 +20 with a 265 in the rear will NOT put his 2jz power to the ground as effectively as a 265 with a higher offset wheel!*** And good job making up your "purposed" aspect ratios in your new post haha. You never mentioned them earlier. I quoted your original post to refresh your memory. ![]() Sorry you got all butt hurt about me disagreeing with your recommendations and using the super duper offensive f word when i did it. Oh and by the way..You are just a narrow minded 31 year old ass. ![]() |
#1736 |
![]() Front - 17x9+15 255-40-17 NT05 - -2.2* Front fenders are rolled only. |
#1737 |
Nick_04K, pipe down. I'm not gonna bother bickering with you. If you're poking around in this thread, I would have thought the aspect ratios for 17's & 18's would be obvious. My bad for not spelling it out for you, I guess.
The guy asked for a recommendation. I gave my opinion. You disagreed with it. Fine. Obviously, neither are wrong. They're just different. Hopefully the guy who asked will be happy that he has options to pick from for his new setup, because there's more than one way to skin a cat, as they say. Now drop it. |
#1738 |
![]() Feedback Score: 12 reviews
Its also worth noting that the setup I have posted on there is different than the setup I mentioned above. Let's try not to spread misinformation or call anyone and everyone out.
#1739 | |
![]() Join Date: May 2009
![]() Sigh... Sry for this meaningless post. I didn't see the reply with his wheel specs. Sorry again. Last edited by kojiki88; 01-23-2011 at 12:23 PM.. Reason: Didn't notice the reply. |
#1740 |
