Old 01-27-2004, 12:49 PM   #1
S13Koop
S13Koop's Avatar
S13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant future
Send a message via AIM to S13Koop
SR Why does my turbo get so hot???
I've noticed my turbo and manifold are getting really hot, what would cause this?
tia,
-will
JZX100
S13Koop is offline   Reply With Quote
Old 01-27-2004, 12:56 PM   #2
Brolewigi
Brolewigi's Avatar
Brolewigi is an unknown quantity at this point
One of two things.
1.The hot exhaust gasses flowing through it from the engine.
2.From running a rich A/F.
It is not going to be cold.
Don't burn yourself...
Brolewigi is offline   Reply With Quote
Old 01-27-2004, 01:05 PM   #3
S13Koop
S13Koop's Avatar
Obviously, but I know it shouldn't be glowing RED hot.
JZX100
Old 01-27-2004, 01:50 PM   #4
Brolewigi
Brolewigi's Avatar
hmmm. Glowing red. Thats not good...
How much boost are you running?
Old 01-27-2004, 01:53 PM   #5
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
yes, all turbos will glow red if boosted hard enough and long enough. for instance, a 50-120 highway pull will generally make them glow.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 01-27-2004, 02:03 PM   #6
einherjar
einherjar is an unknown quantity at this point
when i rape my turbo for a bit, it will start to glow red, its pretty cool looking in the mid-night after drifiting for a bit and seeing it glow.
~SR20DET~,
Side/Top mount I/C, HKS bov,Intake,CP Racing tri-strut bar, retourqued p-plate, custom 5 puck CP racing clutch disc.
einherjar is offline   Reply With Quote
Old 01-27-2004, 02:51 PM   #7
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
mine is doing that too after like a 1 - 3 hard pull, it will glow real red.
gsracer is offline   Reply With Quote
Old 01-27-2004, 03:06 PM   #8
S13Koop
S13Koop's Avatar
ok, i was getting a little worried,
although, is there a way I can get it to glow green or even an indiglo color?
JZX100
Old 01-27-2004, 03:12 PM   #9
Brolewigi
Brolewigi's Avatar
It's not a good thing to see that. But it happens.
Old 01-27-2004, 03:25 PM   #10
Var
Var's Avatar
Send a message via AIM to Var
Originally Posted by Brolewigi
One of two things.
A rich A/F runs cooler than a lean A/F. how come you're saying a rich A/F is causing the heat? The only thing that heats up under rich conditions is a catalytic converter.
Hi
Old 01-27-2004, 03:39 PM   #11
uiuc240
uiuc240's Avatar
Actually, EXCESSIVELY rich will heat things up too. But yes, lean = hot.
Eric
2002 Mazda Protege5
Old 01-27-2004, 03:48 PM   #12
S13Koop
S13Koop's Avatar
did i mention my downpipe is a little dented, probably restricting flow?
new one is on order as well as a test pipe from ProjectSilvia.com
JZX100
Old 01-29-2004, 07:08 PM   #13
NooKa
NooKa's Avatar
NooKa is an unknown quantity at this point
Send a message via AIM to NooKa
Clogged exhaust will do this as well, or at least aid in making it happen.
NooKa is offline   Reply With Quote
Old 01-29-2004, 07:15 PM   #14
S13Koop
S13Koop's Avatar
well I put the downpipe and test pipe on just now, DAMN !!!! this thing is loud as hell!
JZX100
