![]() Join Date: Jun 2010
![]() Hey was good everyone,I just need a little advice on what size injectors to go with my current setup.I have a garret gt28r should i go with 550 or 650? And where should i get a rom tune? jwt nistune enthaply?
#2 | |
Nistune is great if you wanna tune yourself or have a good local tuner
Yes 650 will be good for more hp, but 550's will do just fine also.. If you are planing on going for more in the future, just get the 650's now, and not have to worry later.
Ok good look on the input is jecs a decent company?i saw a set of 650 for like 230... wich is considerably cheap compared to others.By the way they are remanufactured and come with a flow test sheet>
![]() Join Date: Aug 2007
base it off your future goals and current engine management.
if your running a rom tune with a SAFC stick with 550cc's if you have a standalone or are going to soon. go 650cc's |
#10 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
<meatloaf>took the words right outa my mouth</meatloaf> To the O/P (and to mimic Bardabe), go with the biggest injector you can. 550's will get you to 350ish whp before being maxed out, so why not go with 740's and be done with it.
![]() Join Date: Jul 2008
Injectors arent turbo suitable based, you could be running a TD06 on 550cc injectors.
They will max flow on HP rating achiveable, on an SR20 your looking at maxing out 550cc injectors at around the 220-240rwkw mark. So if your only planning to run 200rwkw in an SR20 with that turbo 550cc is MORE than enough, but if down the track your really thinking of running more boost more power, then it would be nice to run 650/740's so your only running them at 60% load over 100%
so what kind of whp or bhp should i get with this setup,tomei 260,bc dual spring and ret,gt28r,740cc inj,greddy fmic, trust 3.5 inch exhaust greddy turbo elbow and dp,z32 mafs and nis tune.and what boost settings should i run with avcr
#14 | |||
Trader Rating: (58)
But the end comment is true, I'd rather run a larger CC injector at a much lower duty any day of the week. However I can't deny how 'tough' some injectors have proven to be at close to 100%. Quote:
You should see 300-325 whp at big boost. Trust me when I say I'd strongly suggest going 2871r before you even get it set up...it will spool darn near as quickly as the 28r, but make 300 whp at amuch lower boost, while allowing much more power on the top end. Quote:
Search for the '2871r thread' and read it all.
#15 |
Well the place jgy where im getting the stuff from, said i can use bc springs i originaly i wanted tomei springs but they recomended bc they said its the same as tomei and basically im paying for a name.my gt28r is brand spanking new so i will stick with that for a while.then sell it then upgrade.
#16 | |
Trader Rating: (58)
...amazing that people still us them :/ JGY suggesting BC springs/retainers is complete awful suggestion, especially when they are nothing more than a copycat company with no real RD section. If you have tomei cams, run tomei springs. HKS cams? HKS springs. JWT Cams? JWT Springs. I'd still sell the 28r and look at a 2871r setup if I were you. You're only going to be upset knowing you could have a turbo capable of another 50-75 whp, much more torque and average power, all on the same setup.
#17 |
Ok thanks ,i will change the order from bc springs to tomei will i be able to rev higher?ill prob sell my turbo after i put like 1000 miles on it,the dam turbo cost me 800 a couple years ago.
#18 |
Yes and trust me i know about the horror stories they took three months to do my wiring harness,ill never have them work on my my car or any of there services.But they do hook me up on prices and allow me to do payment plans.
#19 | |
Trader Rating: (58)
The major limiting factor of 'safe' additional revs (that is, 8000-9000) really are the lifters
#20 |
well the gt28r will be good for now,im really trying to set my s14 for drifting,i do want that gt2871r tho i wish the guy would have got me that turbo instead.Originaly i was going with gt28rs but jgy shipped the shop in my town the wrong turbo at that point i had no knowledge and i was in a rush to do my swap>
#22 |
![]() Join Date: Oct 2001
![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
doesnt matter between the two... get the cheaper set and put the savings towards a better tuner
i went from 650's down to 550's and made 12whp more... tired injectors i guess. same tuner, rest of the set up was the same.. 650's were 2-3 years old. |
