Old 07-18-2003, 01:40 PM   #1
240Degrees
240Degrees's Avatar
240Degrees is making a name for him/her self240Degrees is making a name for him/her self
Send a message via AIM to 240Degrees
S14 vlsd into S13?
I have a jdm s14 vlsd w/o ABS that I want to put into my S13 w/o ABS. So all I have to do is swap the rear covers, and get longer studs. How long studs do I need? I also don't have the bushings that go in the front mounting holes in the S14 vlsd. Where can I get these? The dealer?
tentacles??? wtf!?
240Degrees is offline   Reply With Quote
Old 07-18-2003, 02:26 PM   #2
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
go to www.acceleratedconcepts.com email Jeremy they were working on a kit at one point that gets everything perfect for you. if nothing else he can tell you what all you need to get it sitting right.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 07-20-2003, 02:13 AM   #3
240Degrees
240Degrees's Avatar
i ordered the bushings from nissan. They wanted 40 bucks for the pair!!!! Well I can't find a longer S14 bolt in millimeters. When I checked Home Depot, all I found was standard. WTF!? Where am I supposed to get these bolts??? I don't wanna pay 10 bucks each at the dealer.
Old 07-20-2003, 04:14 AM   #4
MarvynDT
MarvynDT is an unknown quantity at this point
visit your local junkyard and take them off an S14, but just save your time and spend the $$$.
MarvynDT is offline   Reply With Quote
Old 07-23-2003, 04:30 PM   #5
240Degrees
240Degrees's Avatar
I think I found the bolt size I need for the S14 vlsd. It is: 12mm Diameter, 1.25 threadpitch and 80mm lenght.
I found it on freshalloy. http://forums.freshalloy.com/ubbthre...e#Post67427419
Would anyone care to confirm this?
Old 07-28-2003, 08:05 PM   #6
WhiteS12+1
WhiteS12+1 is an unknown quantity at this point
Hey 240 Degrees did u install it yet? I have a USDM S14 waiting to install. Did you ever confirm what size mounting bolts u will need and where to get them from. Also I think I read somewhere that u can use a metal spacer instead of the bushings.
WhiteS12+1 is offline   Reply With Quote
Old 07-28-2003, 10:11 PM   #7
240Degrees
240Degrees's Avatar
I will install it soon. Soon as in this week if these bolts fit, otherwise, in 2 weeks if I need to get bolts from the dealer. I want to be very sure that these bolts work because I picked up a set of bolts from Ace Hardware for my hood, from the drawer labeled metric, but I ended up jacking up all the threads because the bolts I bought were standard. I'll try to take pictures of the official Nissan S14 bushings if I remember to.
Old 07-28-2003, 10:29 PM   #8
240Degrees
240Degrees's Avatar
The s13 differential bolts onto the chassis directly (metal to metal). The s14 differential uses a rubber bushing to mount itself. I've read that if you don't use the bushing, this could make the s14 differential crack. I just went ahead and bought the OEM front mounting differential bushing(better safe than sorry). I can find the product # for it if you want, but any Nissan parts dealer should be able to do it for you.
Old 07-29-2003, 10:24 AM   #9
WhiteS12+1
The differential i bought has only one of the bushings. I am thinking of going back to the yard where i got it and looking for the other. How much were the bushings from Nissan.
Thanks!!!
Old 07-29-2003, 02:16 PM   #10
240Degrees
240Degrees's Avatar
the bushings were about $20 each. s14 front mounting differential bolts were about $10 each.
Old 07-29-2003, 05:44 PM   #11
WhiteS12+1
Where did u get the S14 mounting bolts? Are they longer and will they fit the S13?
Thanks!!!
Old 01-30-2004, 10:51 AM   #12
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
hehe. CHRISTIAN!!!. sell it to me and jay.. or we'll trade u for an s13 vlsd HEHHEE.
Grant is offline   Reply With Quote
Old 01-30-2004, 12:18 PM   #13
Steeles
Steeles's Avatar
that was 5 months ago grant....
