Old 02-15-2011, 01:23 PM   #1
Smkns13
Smkns13's Avatar
Smkns13 is an unknown quantity at this point
Tail light fuse keeps blowing
How's it going. My s13 keeps blowing tail light fuses. Ive done some research and still can't find a short in the wiring. When I first noticedmy tailights out I realized that there wasn't a fuse in it but it was straight wired. I noticed it was a lil bit melted. I put a fuse in and it blew by the time I got home (15 min) later. I replace it with a 25A. Fuse and It blew that one too. I've searched the fuse box and the tail light connections for any wire that might be damaged but can't find any. I saw something on here about an orange wire behind the cd player that could cause this. I see it is connected to a red wire w/ blue line I'm all out of ideas about what to check.
If u guys have any ideas let me know.
Thanks in advance
Smkns13 is offline   Reply With Quote
Old 02-15-2011, 01:43 PM   #2
job4ac0wboy
job4ac0wboy's Avatar
job4ac0wboy is an unknown quantity at this point
The wire is called illumination and if it grounds out then it blows. The tail lamp fuse is tied in with your dash lights. So If you ground the wire the lights go and the fuse blows. My illumination wire is not connected to anything and it grounded out. I taped off the end so it cant be grounded, swapped the fuse, and it fixed the problem. For now. It works for me so give it a shot bro.
job4ac0wboy is offline   Reply With Quote
Old 02-15-2011, 03:40 PM   #3
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Don't replace the fuse with a higher amp one, that's how a fire starts. I believe the side marker wires are also tied into the Tail Lamp fuse, along with the cluster illumination and tail lamps. Follow the wires and see if they are grounding out somewhere.
Old 03-07-2011, 07:42 PM   #4
nv1992
nv1992's Avatar
nv1992 is an unknown quantity at this point
i have the same prob. figured i would search before i tried postinn a thread. ill try tapin off a the illumination wire tomorrow
nv1992 is offline   Reply With Quote
Old 03-08-2011, 05:46 AM   #5
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
i had that problem it came out to be a stripped wire was touching another wire. in my corner lights
Old 03-08-2011, 05:56 AM   #6
gallo
gallo's Avatar
gallo is an unknown quantity at this point
I'm having the same problem except it blows the bulbs one by one i'n the tail lights maybe once a month and my 3rd brake light won't work I tried chasing the wires on the brake light and cannot find why it's not getting current to it
gallo is offline   Reply With Quote
