Old 01-30-2004, 11:02 PM   #1
XXX4life
XXX4life is an unknown quantity at this point
Send a message via AIM to XXX4life
put intake on and the car won't start??
ok i have a 90 240sx so ka24e motor, i put an intake on it and it wouldn't start?? i noticed there was a sensor on the old airbox so i took that off the air box and left it plugged in, it still won't start?? i don;t get it? i put the airbox back in and it starts? can someone please help me
thanks
04 Scion xb
90 240sx (ka24de)
www.entrustclothing.com
XXX4life is offline   Reply With Quote
Old 01-31-2004, 06:26 AM   #2
Brolewigi
Brolewigi's Avatar
Brolewigi is an unknown quantity at this point
There is your problem. The car needs the MAF sensor to operate. Its almost like doing a lung transplant and taking out your diaphram so you can't breathe. Put your old intake back on.
Brolewigi is offline   Reply With Quote
Old 01-31-2004, 06:50 AM   #3
thx247
thx247 is an unknown quantity at this point
dunno what intake you have, but that sensor you took off tells the motor how much air was drawn in, if the intake does not have a place to use that sensor, time to go back to stock
thx247 is offline   Reply With Quote
Old 01-31-2004, 08:54 AM   #4
XXX4life
i didn't remove the maf sensor, so that little sensor on the airbox need to be in the airbox??
04 Scion xb
90 240sx (ka24de)
Old 01-31-2004, 02:06 PM   #5
matlock
matlock is an unknown quantity at this point
Take some pictures if you can so that we can see what plugs you are talking about, because I would've said MAF also. It's kinda funny I put an intake on my car and the idle fixed, becuase it used to idle rough and now its all good!
matlock is offline   Reply With Quote
Old 01-31-2004, 02:44 PM   #6
G_Fish240
G_Fish240's Avatar
G_Fish240 is an unknown quantity at this point
Send a message via ICQ to G_Fish240 Send a message via AIM to G_Fish240 Send a message via Yahoo to G_Fish240
you probably have your mafs on wrong
Sacramento touge and drift
MakotoS13: Spreading BS and being an ass on zilvia since June 2004
G_Fish240 is offline   Reply With Quote
Old 01-31-2004, 02:58 PM   #7
Var
Var's Avatar
Send a message via AIM to Var
I think I know what it is. It's the IAT sensor(Intake air temperature) i put a resistor in mine so it tells my ecu i'm constantly getting 57 degree air. Get this resistor from Radio Shack or wherever they sell resistors and install it on the sensor, then cover it up with e-tape.
4.7k ohm, 1/2 watt resistor. This is documented to work on a Camaro but in theory they are both 5 volt sensors so it should create the same reading on all 5 volt sensors. Good luck.
Hi
Old 01-31-2004, 04:05 PM   #8
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
That's exactly what he is talking about...Some of the CAIs come with a bung past the MAFS to plug the Intake Air Temperature (IAT) sensor in, eliminating the need for that procedure.
zero.counter is offline   Reply With Quote
Old 01-31-2004, 04:59 PM   #9
XXX4life
i just went and messed witrh it some more, i pulled the sensor out of the airbox and start the car, it started and ran fine, then i moved the airbox and everything and put the cone on and it won;t start??? the maf is still plugged in i haven't touched it, this is pissing me off it's doesn't make any sense
04 Scion xb
90 240sx (ka24de)
Old 01-31-2004, 05:19 PM   #10
zero.counter
Remember what westboroughpimp said and use this as a guide for the resistance...
Sorry for the size, but the plan works....
