Old 02-25-2011, 04:18 PM   #1
SoCalDrifter
SoCalDrifter's Avatar
SoCalDrifter is an unknown quantity at this point
My first stock to finish build
Ok so this is going to be my new project ive owned about 5 240s and they were all pretty much done just missing a few things so now i just sold my coupe and decided that i wanna build a hatch from stock to what i consider finish. This thread will probably be updated 2-3 times a month with new parts that i get and install, im going to be doing almost everything on the car myself with the help of my friends. I just picked this car up about 2 weeks ago (from NGKpower) and this is what is already done to it:
*Gasket set, dismantled, had a friend hot tanked the head. Purchased another head and slapped it on, replaced all gaskets and timing chain kit.
*Brand New Exedy OEM clutch kit
*BM short shifter
*5 speed swap using all Nissan parts: 5 speed driveshaft, CMC with hardline and slave. 5 speed pedal, and 5 speed brake pedal.
*Wire tuck with battery fuse box mod
*Eibach sport line springs
*Koyo Radiator with 2 12" electric fans and a Thermostatic relay switch.
*Chinapexi N1 Dual exhaust catback
*JDM 180sx IKI H4 housing with H4 HID Kit
*ACC/ON/Start buttons
*S14 SE Seats
* Custom tail light panel
* Z32 26mm Calipers
* Z32 cross drilled rotors
* New Stainless Steel front brake lines
* Removed the oem dynamat with Dry ice
* New oem rear Spoiler
* Lazy eye mod using the rear defogger switch
* Painted the engine
* New Autozone upper and lower radiator hoses
* New drive belts, Alt. P.S.
* Nissan Coolant
* Newer Clean Dash
* Boss Hub
* NRG quick release
* Nardi 330mm Steering wheel
* New spark plugs
* New ignition wire
* New drop in air filter
* Removed the high pressure power steering hardline bracket.
* Custom Urethane Tranny mount
* OEM engine mounts
here are some pictures of it:
My plans for this car are going to be for track/weekend use but also a really clean look,i plan on doing my suspension first and for under the hood i plan on doing a KA-T for around 270-300hp.
As of right now i am looking to buy a few things for my car already if anyone has hatch carpet im not really pickey about the condition and not really looking to spend alot of money, cf hood, and a cf trunk, also wouldnt mind getting a supermade body kit if anyone has one for sale in good condition but thats all i can think of for know. All comment/sugestion/feedback are welcome and for all the people that are gunna leave negative feedback keep it to yourself cause this is my car and im gunna do what i want with it, if you would like something done to it you can give me money to do it and ill consider doing it. thanks.
SoCalDrifter is offline   Reply With Quote
Old 02-25-2011, 04:42 PM   #2
h2v7
h2v7 is an unknown quantity at this point
unless its a complete build thread dont post it?
IBTL
h2v7 is offline   Reply With Quote
Old 02-25-2011, 05:51 PM   #3
jack
jack is an unknown quantity at this point
IBTL
im pretty sure this is a build in progress and it will be complete when hes done
jack is offline   Reply With Quote
Old 02-25-2011, 06:03 PM   #4
Jlugo711
Jlugo711 is an unknown quantity at this point
Hell, I didn't even know a build could be "complete". *shrug*
Jlugo711 is offline   Reply With Quote
Old 02-25-2011, 06:15 PM   #5
SoCalDrifter
once i run out of money to put into my car ill consider it done untill i get more money to put into it
Old 02-25-2011, 06:56 PM   #6
dj_hype
dj_hype's Avatar
dj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of lightdj_hype is a glorious beacon of light
Send a message via AIM to dj_hype
This. Builds never finish. They just stall out for a while until you pimp yourself out to enough fat chicks to buy the next part.
http://www.ericisaboss.com
dj_hype is offline   Reply With Quote
Old 02-25-2011, 07:21 PM   #7
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
Or a rich old lady! Lol
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 02-25-2011, 07:42 PM   #8
slomar91
slomar91 is an unknown quantity at this point
It looks like... a stock 240sx. Half of your "build" is just maintenance. And it looks like your battery is just sitting on the floor.
slomar91 is offline   Reply With Quote
Old 02-25-2011, 07:56 PM   #9
sincity_sil80
sincity_sil80's Avatar
sincity_sil80 is an unknown quantity at this point
clean platform to start with nonetheless. but whats with the taillights??? not my thing but like you said...your car, gl
20 till 3:00 =
sincity_sil80 is offline   Reply With Quote
Old 02-25-2011, 08:12 PM   #10
SoCalDrifter
i got it that way ive already taken it off the guy i got it from made it out of fiber glass
Old 02-25-2011, 08:25 PM   #11
sincity_sil80
o i c ... well gl with the build bro
20 till 3:00 =
Old 02-25-2011, 09:36 PM   #12
iBlaze240
iBlaze240 is an unknown quantity at this point
looks solid but yea like said before, half that build is maintenance...unimportant. and why do you have two batteries? the one in the bay isn't even hooked up. otherwise clean though GL
iBlaze240 is offline   Reply With Quote
Old 02-25-2011, 09:42 PM   #13
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
^this, two batteries?
bc. is offline   Reply With Quote
Old 02-25-2011, 09:44 PM   #14
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
2>1 .......
S14kouki_10 is offline   Reply With Quote
Old 02-25-2011, 09:46 PM   #15
iBlaze240
LOL, probably balances out the car, like a Honda...amiright?
Old 02-25-2011, 10:11 PM   #16
Big Zee
Big Zee's Avatar
Big Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choicesBig Zee has made poor choices
Send a message via MSN to Big Zee
battery fuse box mod ? is there a writeup on that ?
Big Zee is offline   Reply With Quote
Old 02-25-2011, 11:39 PM   #17
SoCalDrifter
hes right on this the batterie in the engine bay is FAKE since the engine has such a clean wire tuck its been tucked into a fake batterie heres a picture
Old 02-26-2011, 05:28 PM   #18
iBlaze240
Oh that is pretty cool. Well I'm in for updates. Hope this doesn't die out
Old 02-27-2011, 03:59 PM   #19
h2v7
actually that fake battery is pretty cool...
