Old 07-18-2007, 11:42 PM   #1
sunnys14
sunnys14's Avatar
sunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nicesunnys14 is just really nice
SR bearing clearances
my s13 blacktop spun bearing so im going to get new bearings machined. do rwd SR's have the same bearings and bearing clearances as a fwd SR?
sunnys14 is offline   Reply With Quote
Old 07-18-2007, 11:46 PM   #2
crazyikimasho
crazyikimasho's Avatar
crazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond reputecrazyikimasho has a reputation beyond repute
They should be the same. But... just to be sure check online FSMs for actual specs. This is one area you want to be very precise.
In case you're not sure where to start searching for FSMs
heres a start... http://www.zeroyon.com/index/content/view/24/47
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan.
crazyikimasho is offline   Reply With Quote
Old 07-18-2007, 11:59 PM   #3
sunnys14
sunnys14's Avatar
i got the rwd SR fsm already, but i just dont know the clearances for a FWD SR...
Old 07-19-2007, 06:49 AM   #4
Mazworx
Mazworx's Avatar
Mazworx is making a name for him/her selfMazworx is making a name for him/her self
I always loosen them up from factory. Especially if you plan on making more power than factory. We also machine oil grooves in the mains and then run some good race bearings.
Mazworx is offline   Reply With Quote
Old 07-19-2007, 09:42 AM   #5
steve shadows
steve shadows's Avatar
good point right here.
The bearings lifetime goes down, but you probably wont be planning on racing the car for more than 20,000 miles straight anyways. at least i wouldnt without a tear down and inspection.
Like Me on FaceBook !
Old 07-19-2007, 11:51 AM   #6
lonelydrifter
lonelydrifter is making a name for him/her selflonelydrifter is making a name for him/her self
If you are replacing bearings you have to take the engine apart so while its apart just measure the clearances and order the appropriate bearings. Don't go by color markings on OEM bearings. Clevite FTW!!
lonelydrifter is offline   Reply With Quote
Old 07-19-2007, 11:54 AM   #7
Dousan_PG
Dousan_PG's Avatar
oem is fine
ive seen a few clevite problems thru freshally of people's rebuilds
oem is 100% fine and works good.
Aaron
Pink GodziRa
Old 03-11-2011, 10:23 AM   #8
Andrew@9K
Andrew@9K's Avatar
Andrew@9K is an unknown quantity at this point
ACL H series has different part numbers for the SR20DE and DET I believe they are the same sizes but what I did notice is that the DET bearing has a few more oil holes in it and 270 degree oiling. Good engine bearings arent really gonna make you anymore power but what your paying for is the added protection from wear thanks to the coatings they use. OEM is great too FYI hope this help -Andrew
These have given me great results in previous builds
Andrew@9K is offline   Reply With Quote
Old 03-11-2011, 10:26 AM   #9
Andrew@9K
Andrew@9K's Avatar
btw did you spin a main bearing or a rod bearing?
Old 03-11-2011, 10:31 AM   #10
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
this thread is like 4 years old...
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 03-11-2011, 10:58 AM   #11
Andrew@9K
Andrew@9K's Avatar
whoa! my bad i didnt check the dates thanks for the heads up bro
