Old 03-14-2011, 06:02 PM   #1
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
oil filter relocation install HELP
Retarded question....i know.
But what is the path of flow for an oil filter relocation kit with cooler?
There are two holes on the adapter that goes to the block, and two holes on the oil filter relocation block. Which is in/out on both of these?
Basically, one port flows directly into the middle of the filter, the other flows to the outer circle of the filter. Which is in, which is out?
Thanks guys.
gotta240 is offline   Reply With Quote
Old 03-15-2011, 06:23 AM   #2
s14_sr20_silvia
s14_sr20_silvia's Avatar
s14_sr20_silvia is an unknown quantity at this point
I'm fairly certain that if you look at the block adaptor the hole on the left is out and the hole on the right is in.
On the filter the hole in the middle of the filter is in, and the one offset to the side is out.
Last edited by s14_sr20_silvia; 03-15-2011 at 06:30 AM.. Reason: Found a picture to demonstrate.
s14_sr20_silvia is offline   Reply With Quote
Old 03-15-2011, 06:24 AM   #3
s14_sr20_silvia
The small questions thread probably would have answered this quicker.
