![]() Join Date: Dec 2005
SR injectors not firing
What ive checked to eliminate other bad parts.
Walbro works perfect CAS works perfect Getting proper fuel pressure ECU works perfect Ive tested with another set of injectors same issue What do you think? Ive stumped myself and I think Efrain (hard to do) lol Thanks for input |
![]() Join Date: Sep 2005
From an electrical standpoint the injectors will not fire for 2 reasons.1: No 12v or 2: No ground trigger. Verify the injectors have a constant 12v. If that is true, we know it's a grounding issue. Most likely the wiring or ecu. Test the continuity of the injector ground wire pin from ecu to the corresponding injector.
Tip: continuity test is not really conclusive, as it only takes 1 strand to create continuity but highly unlikely. G\L
![]() Join Date: Sep 2004
Also make sure to check your engine bay fusebox, should be a 7.5-10amp fuse that handles the injector pulses. If that's broken, injectors wont fire. =)
#7 | |
#11 | |
That fuse is on the 12v side it also controls ECCS..., I believe, they usually blow thru human intervention! The ecu would be running off of the backup power.
And that's why i said, Quote:
There's also the wiring at the wheel well area that gets corroded over time, I was also using the 12v signal ref to determine if that was the problem. Still waiting on verification either way.
anyone have a diagram of the ground trigger system for the injectors/ecu? I'm having the same problem I think.
k sorry took so long back from vacation decided to get a noid light set and test, looks like no power is getting to injectors.
Since i didnt do the harness im going to pass it down to the guy who did it to try and solve issue. |
#14 | |
Also I dont have ANY chassis harness in the car, just whats needed (lights, turns, etc) |
