Old 03-07-2011, 11:16 PM   #1
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
SR injectors not firing
What ive checked to eliminate other bad parts.
Walbro works perfect
CAS works perfect
Getting proper fuel pressure
ECU works perfect
Ive tested with another set of injectors same issue
What do you think? Ive stumped myself and I think Efrain (hard to do) lol
Thanks for input
i need tires is offline   Reply With Quote
Old 03-07-2011, 11:31 PM   #2
chetos13
chetos13's Avatar
chetos13 is an unknown quantity at this point
Send a message via Yahoo to chetos13
check ground located behind the intake manifold close the firewall. should be 2 grounds
TEAM ELITE
chetos13 is offline   Reply With Quote
Old 03-07-2011, 11:36 PM   #3
i need tires
Will do thank you!
Old 03-08-2011, 02:49 AM   #4
zurud
zurud is an unknown quantity at this point
Check the voltage going to the injectors
zurud is offline   Reply With Quote
Old 03-08-2011, 06:38 AM   #5
cotbu
cotbu's Avatar
From an electrical standpoint the injectors will not fire for 2 reasons.1: No 12v or 2: No ground trigger. Verify the injectors have a constant 12v. If that is true, we know it's a grounding issue. Most likely the wiring or ecu. Test the continuity of the injector ground wire pin from ecu to the corresponding injector.
Tip: continuity test is not really conclusive, as it only takes 1 strand to create continuity
but highly unlikely. G\L
Old 03-08-2011, 08:13 AM   #6
Om1kron
Om1kron's Avatar
Also make sure to check your engine bay fusebox, should be a 7.5-10amp fuse that handles the injector pulses. If that's broken, injectors wont fire. =)
Wayne Edwards
https://om1kron.blogspot.com
Old 03-08-2011, 11:25 AM   #7
i need tires
Ill check this tonight and see what happens.
Old 03-08-2011, 11:33 AM   #8
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
+1 on the grounding.
GroundPerformance is offline   Reply With Quote
Old 03-08-2011, 11:36 AM   #9
i need tires
car is wired painless style so no OEM fuse box
Old 03-09-2011, 12:28 AM   #10
Om1kron
Om1kron's Avatar
doesn't matter, the injectors is still something that is fused.
Wayne Edwards
Old 03-09-2011, 01:23 AM   #11
cotbu
cotbu's Avatar
That fuse is on the 12v side it also controls ECCS..., I believe, they usually blow thru human intervention! The ecu would be running off of the backup power.
And that's why i said,
If there is no 12v ref, then I would have lead him down that road. Good call though!
There's also the wiring at the wheel well area that gets corroded over time, I was also using the 12v signal ref to determine if that was the problem.
Still waiting on verification either way.
Old 03-09-2011, 08:17 AM   #12
Gription
Gription's Avatar
Gription is an unknown quantity at this point
Send a message via AIM to Gription
anyone have a diagram of the ground trigger system for the injectors/ecu? I'm having the same problem I think.
Gription is offline   Reply With Quote
Old 03-15-2011, 09:01 PM   #13
i need tires
k sorry took so long back from vacation decided to get a noid light set and test, looks like no power is getting to injectors.
Since i didnt do the harness im going to pass it down to the guy who did it to try and solve issue.
Old 03-15-2011, 11:37 PM   #14
i need tires
no 12v to the injectors when ignition is on.
Also I dont have ANY chassis harness in the car, just whats needed (lights, turns, etc)
Old 03-15-2011, 11:57 PM   #15
Team DET
Team DET's Avatar
Team DET is on a distinguished road
Have you checked if you ignitor is good.I had the same problem with injector #3 not firing,ignitor was cracked at the plug
(OΞO/- -\OΞO)
Team DET is offline   Reply With Quote
Old 03-16-2011, 12:06 AM   #16
i need tires
havent tested ignitor, with starter fluid engine runs, so I assumed the ignitor is good. Would I still get spark with bad ignitor?
Old 03-16-2011, 01:29 AM   #17
zurud
The injectors are hot all the time. Constant 12v. Your wiring is messed up
Old 03-16-2011, 01:16 PM   #18
i need tires
This is what ive come down to, person who did wiring is coming by this weekend to get this squared up
