Old 03-17-2011, 02:02 AM   #31
Krazykouki
Krazykouki is making a name for him/her selfKrazykouki is making a name for him/her self
I cannot get my stock ebrake to lock up the wheels no matter the speed in a straight line. I have brand new rear rotors and pads but I have fresh 275's in the rear. I was able to get it to lock them up with ease when I had 235's on the back though.
Krazykouki is offline   Reply With Quote
Old 03-18-2011, 10:36 AM   #32
bb4_96
bb4_96 is an unknown quantity at this point
^ sissy bar?
bb4_96 is offline   Reply With Quote
Old 05-04-2011, 01:57 AM   #33
JDMStanced
JDMStanced is an unknown quantity at this point
you guys want to sell me your cnc handle bar so that i can make custom wilwood set up? lol
JDMStanced is offline   Reply With Quote
Old 08-09-2012, 12:22 PM   #34
s13drifterbabe
s13drifterbabe is an unknown quantity at this point
Has anyone resolved this issue?
I'm having the same exact problem with my hydro ebrake. I have to pull the ebrake handle with pretty much both hands very forcefully while going in a straight line, and even then, it barely locks. The ebrake handle only travels about an inch.
Friends have helped me bleed the system over and over and over again, still same issue.
I tried switching the brake lines on the hydro and all it did was pushed fluid into the master brake cylinder reservoir. I so switched the lines back the way it was.
Any help?
s13drifterbabe is offline   Reply With Quote
Old 08-09-2012, 12:24 PM   #35
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Your e brake cables are stretched
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 08-09-2012, 12:25 PM   #36
rb25_s13*CHUKI
either get new cables or get a hydro ebrake setup
Obliterate
Old 08-09-2012, 12:26 PM   #37
rb25_s13*CHUKI
Also some good brake pads would help out alot, get the hawk hp+ brake pads, that have a good bite to them!
Obliterate
Old 08-09-2012, 12:51 PM   #38
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
what size master cylinder on the hydo?
whats the bore size on the rear pistons?
how long is the handle on your hydro?
I have the same problem with my E36, ASD pass through set-up, connecting to rear brake lines. The pull was Rock hard, and it only moved 1/2 an inch. I increased the size of the leaver, it helps a lot, locks the rears instantly
Chrischeezer is offline   Reply With Quote
Old 08-09-2012, 01:13 PM   #39
s13drifterbabe
It's a stock S13 master cylinder, K-sport standard hydro 5/8", rear brakes are stock S13 with less than 1 year old brake discs & pads.
Old 08-09-2012, 01:20 PM   #40
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I'm using 3/4" Wilwood cyl
Stock s13 calipers, Shitty autozone pads
Handle is about 16" +/-
Locks super easy, good amount of travel on teh handle as well. Locks at 5mph to ---mph, straight line, no problem.
I think it has alot to do with the way the leverage point is.
di-devol is offline   Reply With Quote
Old 08-10-2012, 06:59 AM   #41
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
I see this A LOT.
I have ASD 16" pull back. dual z32.
USE CHEAP PADS. seriously go to the autoparts store and buy the cheapest of the cheap pads!! i promise!
Ceramics and ebrakes DONT WORK.
gsracer.. saw you at CFRC couple weeks ago. SICK. you were entering silly fast by the end of the night!
ch1873857 is offline   Reply With Quote
Old 08-11-2012, 08:06 AM   #42
s13drifterbabe
There is a very nice setup. Where can I buy a handle like that?
Old 08-12-2012, 06:44 PM   #43
ch1873857
looks custom. you can get a similar one assembled and ready to go from ASD motorsports for 180. its pretty amazing. this is the standalone master version
