Old 02-08-2004, 01:33 AM   #1
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
s13 what do i have to do to make it fit?!
i have an '89 non-abs s13 and i have a '94 vlsd from a j30. how the heck do i make it fit? i heard it's been done, but what's wrong with my car?!
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 02-08-2004, 05:24 PM   #2
PSI240SX
PSI240SX is an unknown quantity at this point
as long as the J30 VLSD has 6 bolt output flanges, all you have to to is unbolt your diff and install the new one. If the J30 has 5 bolt flanges, you will need to go back and get the axles off of the car and then install them into your 240. All this nonsense about having your driveshaft shortened... I have done 4 J30 lsd's into 240sx's with no problems always using the factory, non-modified driveshaft.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 02-08-2004, 10:59 PM   #3
Dutchmalmiss
i have the 5-bolt one and i bought the matching 5 bolt axles for it. the axles seem too long.
Pignose, biaaatch.
Old 02-09-2004, 05:48 AM   #4
PSI240SX
they may seem to long but I assure you they will fit. The longer axle goes on the passenger side.
Old 02-09-2004, 08:15 AM   #5
Mr. Spool
Mr. Spool is an unknown quantity at this point
are there any drivability issues with the longer axels, also are these lsd's any good I have heard that they have different gear ratios, that hurt your top end speed.
96' SE Turbo'd
Super 60, S-AFC, SMIC, 370cc Injectors,
Open Air BOV, Warblo 255 pump, Stage 3 Clutch
Kyb agx, Sportline Springs
Full body kit, Bomex rear, Drift sides, r34 front
gunmetal rims, yok tires
Mr. Spool is offline   Reply With Quote
Old 02-09-2004, 07:12 PM   #6
Dutchmalmiss
my neighbor talked about axles and stuff and he said that if it was a bit long, it might bottom out, or something like that. he also said something about the dust cover or something rubbing against the hub? not sure with the terms though, but i hope you know what i mean, PSI240SX
Pignose, biaaatch.
Old 02-10-2004, 05:59 AM   #7
PSI240SX
I removed my dust cover when I switched to 5 lug hubs. But I have done a J30 LSD without having to remove them. The axles are the exact same size.... I just did a swap on thursday night of last week using J30 axles.
Old 02-10-2004, 03:20 PM   #8
Dutchmalmiss
was the s13 you put it in have abs? cuz mine doesn't.
Pignose, biaaatch.
Old 02-10-2004, 07:02 PM   #9
PSI240SX
S13 no abs.
Old 02-10-2004, 08:35 PM   #10
Dutchmalmiss
alright thanks PSI240SX, ill try it again this weekend.
Pignose, biaaatch.
Old 02-10-2004, 11:20 PM   #11
Dutchmalmiss
oh yeah, one more thing...how do you take off the dust cover???
Pignose, biaaatch.
