Old 03-31-2011, 12:19 PM   #1
KAs14slider
KAs14slider is making a name for him/her selfKAs14slider is making a name for him/her selfKAs14slider is making a name for him/her self
So can a ball joint be bad without there being any play in it? What else in the suspension would really get strained when you add a wheel spacer?
Corndrift Blog
KAs14slider is offline   Reply With Quote
Old 03-31-2011, 02:52 PM   #2
thesandman6
thesandman6 is an unknown quantity at this point
If the wobble feels like a ball joint is bad and they are good, take the lcas off, see if the holes for the bolts have been enlarged on the subframe, and check for wear on the bolts. When I got my car it had symptoms similar to yours caused by the control arm moving around when I would hit bumps.
thesandman6 is offline   Reply With Quote
Old 04-01-2011, 04:47 PM   #3
KAs14slider
Did you ever throw spacers on and it made it 10x worse?
Corndrift Blog
