![]() I made a rookie mistake and took my car to a mechanic ive never been to before to have him replace the washers on the turbo coolant lines.
He ended up taking out the entire setup to replace them, in the process he messes up the threads for the oil feed line right below the P/S pump. He was going to attempt to put Helicoil in there but I wasnt comfortable with his work so I told him to leave it alone, I may plug the hole up and taek the feed from elsewhere, and that I needed to assess the situation and see how bad the threads are. This took place over the phone When I come to pickup the car, he has already plugged up the hole with a different thread screw. Started the car to see if it leaks. I am extremely pissed but at this point, I have the following two options and need your help on whats the best route for me to go. Should I a. take out that plug and put the standard M12 1.25 thread helicoil inserts and use the hardline to run the oil to the turbo? Can this be done with the engine in the car? b. Leave that bolt closed and run the oil feed from elsewhere. 1. I have a greddy oil relocation kit that has 2 holes for I believe an oil pressure sensor and an oil temperature. Can I somehow plug into that and take that to the turbo? Is that enough pressure? What kind of steel braided lines would I need 2. Should I BUY a sandwich plate to push the oil from the Oil filter location. What should I do? My car is dead in the water I had it towed home. Really bummed out about something so minor ending up to be a PITA. I am running a S13 SR20DET T25 Stock turbo with all stock lines. I do not have the A/C compressor unit. This is in a 95 240SX Body.
![]() Join Date: Dec 2006
Either helicoil the feed or
buy some steel braided lines (recommended) and have an -AN male fitting welded to the feed hole
might be a pain to weld it on with it in the car,
lol yeah it will hold just fine, this is a common problem and those are the only fixes
hah that sucks man. Are you telling me I need to pull this thing out of the car?
Is this an option and can I do it while the engine is still in the car? DIY stripped oil feed sr20det : 240sx General Discussion
all depends on the space I think you could do it just fine with the turbo assembly off
that'd work too, most ppl would just weld that top portion of the fitting on there so, so you wouldnt have to worry about metal shavings
ah the welding. I cant take the car to a shop I just brought it home. Dont have weld tools or experience.
I do have a GReddy oil filter relocation kit. Should I buy a steel braided line as a temporary fix to drive the car around? Is that a good enough pressure to go to the turbo? is an oil restrictor needed there? edit: I have a greddy oversize oil pan. Should I just take the secondary hole from there? is that also an option. I just need the car up and running
well i would either do the helicoil or that Nico fix (id probably do the Nico fix)
Tha banjo bolt is the restricor (so yes you will need one) the oil pan will not feed oil to the turbo needs be be from th block
![]() Join Date: Feb 2009
Yo this happened to me last month. Stripped the same hole for the oil feed. Just find a small enough drill and put a lil bit of grease on the bit to catch the metal shavings. And for the Helicoil kit, just go on Amazon and look for one.. thats where i got mine. After you buy that kit, you just need to buy a 31/64 drill bit.. got mine from Sears. Good luck.. its pretty easy if u go slow and take your time.
i couldn't get a drill to fit in there while the engine was in. Is there a way i can route the oil from the oil filter temporarily so I can take the car to a shop?
![]() Join Date: Aug 2009
Get a close quarter drill. You can get helicoil from any autoparts store. If you want it welded, call welding shop around you. Somebody must have mobile welder. The AN fitting is thick enough to be welded using spool gun.
remove oil pressure sender cause it worthless any way
buy the ka t25 oil line... it goes from sender 1/8npt to oil inlet on turbo and leave block off on there... i kno the sr block is 1/8bspt but it fits if u screw it in nicely i have an autometer pressure sender screw to my sr for 3 yrs no probs u would need proper tools to do helicoil and the line s would stay oem... this is why ss lines r the best for sr.. so u dont srtip that hole and never let a general mechanic work on a masterpiece like the sr20det
シチサnw/sr20det:stolen |
#14 | |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
i had the same problem...i tried to tap and helicoil the block...it didnt work the first time so i tapped it again and put a hairline crack in the block...it was down hill from there eventually got a new block
#15 | |
just find another oil out put and move on it will be fine the line is like under 30 buks too just check it out 36" T25 TURBO OIL FEED LINE KIT SR20 CA18 KA24 S13 S14 | eBay im gunna opt for for the 1/8 npt - 4-an fitting which is a couple more bucks with problem solved
#16 |
![]() Join Date: May 2009
Damn this sucks, just take out the turbo, headers all in one and you'll be able to have room to work on it.
http://www.iwannagofast.net/ FOR SALE: DOHC maf, KA down pipe and SR A/C pump like new pm me for price. |
#17 |
Man when I did this, i didnt have any problems. Just removed the intake and hotpipe and had enough room to fit a small drill inside. Was a breeze after that. Good luck!
#18 |
A month or more has passed? Damn my car has been parked forever. I figured the best course of action would be to put Time-Sert in which is supposed to be better than Helicoil.
I ended up pulling out the engine, cleaning the hell out of it and the engine bay. Replaced some of the gaskets while I was at it. When the engine was out it was MUCH easier to just Drill and Tap a new Time-Sert thread on there. I'm pretty sure I did it right. I'll find out monday when I start the car. I also tried to find turbo feed lines that would and work for my issue, but it didnt make sense to spend the amount of money only to avoid the problem. Also it was taking far too long to get them in my hand after shipping etc. I just put the engine back in last weekend. Got everything screwed in. This allowed me to finally bolt up the A/C on the SR as well.
