Old 04-16-2011, 08:59 PM   #1
ddf2006
ddf2006's Avatar
ddf2006 is an unknown quantity at this point
KA ka loses power after its warmed up HELP
(ka24de) ok so heres what happines, on cold starts she drives like a champ and pulls great! But once its warmed up and i turn it off and back on, it feels like i have 90 hp. :/ like when im driving normal its ok i guess but the minute i give more then 30% throttle it just gets loud and not go anywhere, like it wants to go but had and anchor on its bumper. I do have a check engine light for codes 32, 33, 34. i changed the knock sensor but im still getting codes for it. any help will be gladly appretiated. (excuse my writing errors, writing this will half sleep)
ddf2006 is offline   Reply With Quote
Old 05-01-2011, 10:52 PM   #2
bigD240
bigD240's Avatar
bigD240 is an unknown quantity at this point
Damn I'm having this same problem!
bigD240 is offline   Reply With Quote
Old 05-02-2011, 01:07 AM   #3
Sileighty_85
Sileighty_85's Avatar
Sounds like a Coolant Temp Sensor
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-05-2011, 04:43 PM   #4
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Maybe you have too much sludge build up lol......JK.
I'd check your temp sensor as well. And check the ecu for codes. It cant hurt.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 05-06-2011, 07:12 AM   #5
rblover
rblover is an unknown quantity at this point
if temp sensors check ok, check your catalytic converter, that will cause same symptom.
rblover is offline   Reply With Quote
Old 05-07-2011, 10:08 AM   #6
Supermini99
Supermini99's Avatar
Supermini99 is an unknown quantity at this point
Have you checked your engine timing?
Supermini99 is offline   Reply With Quote
Old 05-07-2011, 09:34 PM   #7
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Having same problem in my SOHC, lmk if you figure it out and I will also let you know of I figure it out
Mishkin_707 is offline   Reply With Quote
Old 05-22-2012, 11:41 PM   #8
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
im having this same issue, trying to narrow it down atm. any suggestions? down to knock sensor harness, o2 sensor, egr, cat, CTS
http://zilvia.net/f/showthread.php?t=637070 last of my parts f/s
GeneStarWindGSW is offline   Reply With Quote
Old 05-26-2012, 10:03 AM   #9
ddf2006
ddf2006's Avatar
The issue is timing. i redid my distributor and made sure everything was spot on and the problem was solved
Old 05-26-2012, 11:47 AM   #10
Mishkin_707
Thanks, I'm going to see if that's my problem, in the 11 years I've owned my car I never have checked or messed with my timing
codes, ka24de, sensors
