South Western States Arizona, California, Hawaii, and Nevada. |
![]() Join Date: Jul 2009
Trader Rating: (50)
![]() Feedback Score: 50 reviews
![]() like most ka's my ka has that annoying chain rattle or "marble in my engine" sound.
i removed the top metal guide and its still there. looking for someone thats has done this before to fix it. im located in the 909. thanks
wtb s14 roof wing/spoiler! pm me |
Advertiser
![]() Join Date: Dec 2010
Trader Rating: (87)
![]() Feedback Score: 87 reviews
call me at 626-227-4255
I have you covered.
LIKE 9K Racing On Facebook for discount and product updates. ![]() Contact 9K racing for any of your tuning or modifying needs. |
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
My chain was still tight, but one of the guides was gone (tight side) so new guides and tensioner. But I cheated cause I already had the motor out. And ill give you guys my hook up if you find me a s13 fule pump right now. Working
#14 |
![]() Join Date: Dec 2007
Trader Rating: (38)
![]() Feedback Score: 38 reviews
You are suppose to remove the top and side guide. super easy, do it yourself and learn. those bolts on the front cover is less than 20lbs of torque so hand tight is good, just make sure to clean the area and apply some silicon gasket maker.
and yes make sure to redo your distributor. http://www.nicoclub.com/archives/fix...in-rattle.html super easy. |
#17 | |
Trader Rating: (50)
thanks for the link. i took off the very top metal guide. i still have the noise. ![]() if i remove the #2 guide should i buy a replacement or just take it off and leave nothing?
#18 | |
Trader Rating: (38)
but im here to help and not rape your wallet. here i found this paper from Nissan read it. Nissan Service Bulletin NTB98-055a for Timing Chain Noise (chain guide removal) - Nissan Forums: Nissan Enthusiast Forum it says Altima but its applies for the 240sx KA24DE Last edited by 240sxvaj; 05-01-2011 at 11:38 PM.. |
#19 | |
Trader Rating: (50)
i already took guide#1 off ill take guide number #2 off tommorow thanks for the help!!!! ![]() ![]() ![]()
#20 |
if u still have the noise its most likely the tensioner. just take off the valve cover and the front timing cover and ull see it. move it in and out while spraying wd40 on it and there should be a washer on the piston. when ur done, extend it the most u can with ur hand (as to avoid breaking it) and make sure the plastic or metal washer is all the way down (away from the chain). that solved my problem. if it doesnt stop after that then go buy the replacement from nissan. gluck!
#21 |
Trader Rating: (50)
so i finnally took the time to remove guide #2 and check the tensioner.
but now my car wont startt! haha im guessing it has to do with my distributor. how should i go about checking this anybody have this problem before?
