Off Topic Chat All non related chat goes here. |
#1 | |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
Computer Advice
Joined up Hardware Heaven forums in hopes of getting some quick help, but the hardware discussion section is a tad slow.
Figured since there are plenty folk here with computer building knowledge I'd get some help from someone. Recently my friend's dad gave me his some gateway desktop because he simply didn't want to deal with fixing it (motherboard). It's a Gateway DX4640-UB201A (Mediocre Desktop). It's not horrible to look at so I'm not looking for a new case lol. Anyway, I swapped the motherboard and upgraded the power supply to a 480W unit as from what I gathered the supplied 300W unit just wasn't cutting it. Still might end up going with something better.Been thinking about this unit: Amazon.com: Gateway A-Power AK 850W 20+4-pin ATX PSU w/SATA & PCIe (Black) computer: Electronics Because it lacked a hard drive I purchased a 1TB 7,200RPM and it's currently running on Windows 7 Ultimate 64-bit. Been trying to load Ubuntu 10.10, but no dice for some reason. Been getting a BusyBox error of some sort, but I'll figure that out later. Here's where I need some real advice as I'm simply a novice at all this. I downloaded GTA IV to see how it would do and it was horrible. Choppy video and just way to slow. I figure the issue has to be the video card. Did some light research and it's a crappy integrated unit that fails miserably at anything worth playing. Other upgrade I'd like to do is memory wise. It's only 4 GB and considering I'm running 64-bit Windows I believe I'm limited to 16 GB right? I'd be more than happy with 8 GB. I know this is a simple remove and install deal, but not sure what memory to buy. Last thing I want to upgrade are the cooling fan(s). It has one fan over the CPU and that's it. I'd like to upgrade that one plus add at least one more. Again, not sure what to buy. Looking for recommendations that are budget friendly and that will give some good results for someone who's not a total gamer, but wouldn't mind playing some decent games once in awhile. Below are the stock specs just so folks know what I'm dealing with. Quote:
- Jimmy Wanted: TBD For Sale: TBD |
#2 | ||
![]() Join Date: Sep 2004
You want to make some decen't progress and have this thing last you, get a new case and swap the guts, a corsair/coolermaster/or seasonic power supply at least 500w, I'd recommend a 600w. They're not expensive, but then again all 240 owners I know aaaare cheap asses. =) Quote:
It's not going to run any recent games decently no matter how much money you put into it. Upgrading the ram is pointless unless you get yourself a processor worth a shit. I don't want to break your heart but nobody probably responded to your thread because this thing is ancient, for about 900-1200 dollars you could buy a beast machine now. I put together a decent computer for 800 dollars for a friend and this included EVERYTHING he needed to start gaming. I just upgraded from a machine sort of similar to yours and it ran windows 7 like shit. |
Trader Rating: (54)
Far from breaking my heart Wayne. I got the thing for free and I remember my friend used to play FallOut 3 and Left For Dead 2 without any worries. Just wanted to see how the thing would do with GTA IV.
Definitely won't be tossing money out the ass on the thing, but I figured a little improvement here or there would help. How's the power supply worse that the one supplied? I'm not building a gaming pc here simply because I don't really game at all. Also, not limited to gateway components. The PSU posted is not Gateway. The seller just placed that in the title. Seems to be taking Windows 7 pretty decent though. Motherboard is simply a stock replacement like the one below: ACER MS-7399 GATEWAY DX4720 DX4640 MotherBoard MCP73PV | eBay
![]() Join Date: Feb 2002
Check out newegg for the cpu fan and memory. Usually the memory type is scribed on the memory stick itself. Looking at the specs I THINK it's DDR2 667...you will have to do some research on the motherboard to confirm. The memory limitation will also be confirmed after you research more into your motherboard. The OS can address far more than 16GB of memory.
As for the second fan, are you talking about the case fan? That you can also find on newegg, but you need to measure the fan (or opening) to get the right size. You will need a video card if you want to play GTA IV decently. That integrated chip is not designed for gaming.
Goals are dreams with a deadline. L.H.O.O.Q. |
Trader Rating: (54)
Thanks for the advice.
So far I know for certain I should upgrade the video card. I've been looking at the EVGA GeForce GTX 550 Ti, but I'm not certain if it'd be worth it considering my motherboard has a PCI Express x16 slot and that card is a PCI Express x16 2.0. I know I can install it and it'll work, but been reading that it would never run at it's actual capacity. Overclocking on a OEM motherboard is not something I'd like to do. Also, Gateway Bios doesn't allow it apparently so I'd have to get some software that would and frankly I don't think the results would outweigh the risks on hardware that probably wouldn't do well for to long overclocked. The processor should do fairly well, but just to be safe I've been researching a few upgrades that are actually wallet friendly and do the job with no problem From reading up I actually am no longer looking to upgrade the memory. 4GB seems to be more than enough for the games I'm considering and for GTA IV. I will definitely be upgrading the PSU. Looking at Corsairs line up and pairing up the specs with some of the video cards I'm considering. Someone on Hardware Heaven mentioned CoolMasters as well, so I'll look into those. Appreciate the advice and I welcome any other input.
Trader Rating: (54)
gpu I'm considering the 550, but still researching how it'd run with my motherboard. Looking at a few other cards as well.
cpu will stay with the e4700 for the time being. same goes with mobo. psu, 850w? overkill. i'm looking at corsair enthusiast series 550w approximate budget $200-$250 at most. The 550 ti is listed at $150 on newegg (+ $20 mail in rebate & free mafia 2 game coupon). corsair psu is $90 (+ 15 mail in rebate). there are more options, but those are the heavy favorites right now.
If your goal is strictly to be able to play GTA4, this is what you will need.
Newegg.com - GIGABYTE GV-N84S-512I GeForce 8400 GS 512MB 64-bit GDDR2 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video Card and Newegg.com - TOPOWER Galaxis MX Series GAPS-500MX 500W ATX12V v2.3 SLI Ready CrossFire Ready Modular Power Supply ~$70 for both items. Done and done.
Trader Rating: (54)
My goal isn't to just play GTA IV. Don't really have a goal per se, I simply know that if I'm able to run GTA IV with decent settings then I should be able to run any other games I may be interested in that aren't such "powerhouses" like that of GTA IV.
![]() Join Date: Mar 2004
Hmm kinda hard since intel stopped supporting this CPU.
Your mobo choice is limited. Try to find A cheap g33 or g35. this CPU will bottleneck new gfx card maybe eSpecially a 550ti. Its Like vicious cycle of moneypits. That graphic card killer recomended and E4700 should play okay with gta4. I always buy higher watts cause I know I'll upgrade later. Plus psu doesn't get obsolete. And good amount of pcie connectors is all i need. |
Trader Rating: (54)
I won't be upgrading the motherboard. It's not worth it in my opinion. If I end up upgrading to many component then I might as well build a proper gaming pc, which I rather not to because it'd simply go to waste on casual browsing for the most part.
lol so why put any effort in this PC? Just keep it a simple workstation for browsing the web and word processing ha
#14 |
Trader Rating: (54)
Mild effort just for kicks and to make good use of a 27" LCD for some decent games. I just really see no reason to upgrade the motherboard.
Plus got a response on the HH forums that my motherboard actually wouldn't really have much of a negative affect on a new gen graphics card. If that's the case then seems I'm clear on what I'm able to get. Now it's down to making up my mind on which graphics card would offer what I want at a good price. I should add that I appreciate his advice. At the very least I'm learning what could better the system. I know if I drop coin this could easily be a above avg. "rig," but currently a little here or there should be fine.
