Old 05-09-2011, 08:08 PM   #1
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
// SR20DET Parts Galore - LOOK Inside//
Email > [email protected] < Paypal send payment as a personal gift or pay the 3% fee - add in note what your paying for as well as your shipping address.
Concord, NC 28205
Email/PM me offers or to get shipping quotes / I need your City/State/Zip
All prices do not include shipping
__________________________________________________ ____________________________________________
FS: SR20 JE 87mm / 3.425in .040 over stock (86mm / 3.386in) - 8.5:1 CP Pistons
FYI Stock SR20 pistons are - 86mm / 3.386in with a 8.5:1 CP
Will work on any SR20
Used but in perfect working condition
Rings are in good shape but will need to be file fit to your block a new set can be had for $100 or less - if needed
1 piston has been banged around but nothing affects its performance
Another piston has a few scars on the skirt but again will not affect the performance
The carbon build up (not bad at all) will clean right off with whatever way you use - if you dont know any ways to remove it google search there are tons of ways to do it - I just have not had time to clean them.
These are $600.00+ new
$350.00
Download the Piston spec sheet: http://www.jepistons.com/PDFs/TechCorner/S..._instrc4032.pdf
In case you cant read the micrometer - in the first pic - it reads 3.4245 - all pistons are in the range of 3.4245 - 3.425 - this is measuring from bottom of skirt up 1/2in in an 80deg. garage
SR20DET Greddy Oil Pan
Painted black - can be removed easily
1 long and 1 short bolt is missing - $.50 @ hardware store
Each baffle is missing a screw as they dont line up - but they are secure and not going anywhere
Used on a rebuild that made it to idle and then the whole project was parted out.
I was going to use it on my project SR but need $ of other things
$285.00
SR20DET Redtop Valve Cover
Normal wear and tear - nothing major - great for a core on powder coating or use it as-is.
No hardware - valve cover only.
$75.00
If you want a coil pack cover add $25.00
FS SR20DET GREDDY / TRUST / GREX METAL HEAD GASKET
Brand New in Box
I was going to use it on m SR build but need the money for more important things
Part # 13521183
88 1.4mm
This will work on any bore size 88mm and smaller
FYI - Stock SR - Bore & Stroke 86mm x 86mm
$265.00 new from Greddy
http://www.greddy.com/products/engine/meta...er:make:Nissan/
GReddy
$215.00
SR20DET Front timing cover with oil pump
$70.00
SR20DET Bottom mount turbo manifold - turbo mounting stud will need to be replaced
$70.00
SR20DET Ignitor - came off a redtop harness
$55.00
SR20DET Coil pack harness - came off a redtop
$45.00
SR20DET tranny to motor dust plate
$45.00
SR20DET Flywheel - off a redtop needs resurface
$25.00 or $75.00 resurfaced
SR20DET RWD ARP Head Studs
1 torque cycle
$90.00
S13 Redtop SR20DET A/C Bracket
$45.00
S13 SR20DET Fuel Rail w/ caps - no injectors or FPR
$30.00
S13 SR20DET T25 Turbo Lines
$10.00 each or both for $15.00
S13 SR20DET Alternator Bracket - No tensioner bolt/nut
$30.00
SR20DET Brand New Clutch Bolts
$30.00
S13 SR20DET Throttle Bodies with Auto TPS
$25.00
SR20DET Stock Crank, P/S, Alt. Pullies
Crank has small chip on A/C side - Hurts nothing - Only cosmetic
$50.00
S13 SR20DET Intake Manifold (Bare)
$30.00
JDS Performance is offline
Old 05-12-2011, 08:12 AM   #2
JDS Performance
Trader Rating: (53)
bump bump bump
Old 05-12-2011, 12:25 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
bump for my old coil pack cover GLWS
Slip Gypsies Blog
not sure if you realize this
punxva is offline
Old 05-12-2011, 12:28 PM   #4
JDS Performance
Trader Rating: (53)
that one is not for sale just in pix
Old 05-12-2011, 01:45 PM   #5
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
PM sent about CAS
Thanks!
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline
Old 05-12-2011, 02:00 PM   #6
japslapsilvia
payment sent for CAS
Thanks!
Old 05-13-2011, 06:13 PM   #7
BlackTruenoAE86
BlackTruenoAE86's Avatar
BlackTruenoAE86 is an unknown quantity at this point
Send a message via AIM to BlackTruenoAE86
Manifold heat shield shipped to TX?
-Emilio
BlackTruenoAE86 is offline
Old 05-13-2011, 08:27 PM   #8
JDS Performance
Trader Rating: (53)
heat sheilds sold
Old 05-17-2011, 08:06 AM   #9
JDS Performance
Trader Rating: (53)
List updated!
Old 05-17-2011, 09:11 AM   #10
racerx2k1
460
racerx2k1's Avatar
Originally Posted by JDS Performance View Post
bump bump bump
heat sheilds sold
List updated!
racerx2k1 is offline
