![]() Join Date: Jul 2006
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
// SR20DET Parts Galore - LOOK Inside//
// SR20DET Parts Galore - LOOK Inside// Email > [email protected] < Paypal send payment as a personal gift or pay the 3% fee - add in note what your paying for as well as your shipping address. Concord, NC 28205 Email/PM me offers or to get shipping quotes / I need your City/State/Zip All prices do not include shipping __________________________________________________ ____________________________________________ FS: SR20 JE 87mm / 3.425in .040 over stock (86mm / 3.386in) - 8.5:1 CP Pistons FYI Stock SR20 pistons are - 86mm / 3.386in with a 8.5:1 CP Will work on any SR20 Used but in perfect working condition Rings are in good shape but will need to be file fit to your block a new set can be had for $100 or less - if needed 1 piston has been banged around but nothing affects its performance Another piston has a few scars on the skirt but again will not affect the performance The carbon build up (not bad at all) will clean right off with whatever way you use - if you dont know any ways to remove it google search there are tons of ways to do it - I just have not had time to clean them. These are $600.00+ new $350.00 Download the Piston spec sheet: http://www.jepistons.com/PDFs/TechCorner/S..._instrc4032.pdf In case you cant read the micrometer - in the first pic - it reads 3.4245 - all pistons are in the range of 3.4245 - 3.425 - this is measuring from bottom of skirt up 1/2in in an 80deg. garage ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() __________________________________________________ ____________________________________________ SR20DET Greddy Oil Pan Painted black - can be removed easily 1 long and 1 short bolt is missing - $.50 @ hardware store Each baffle is missing a screw as they dont line up - but they are secure and not going anywhere Used on a rebuild that made it to idle and then the whole project was parted out. I was going to use it on my project SR but need $ of other things $285.00 ![]() ![]() ![]() ![]() __________________________________________________ ____________________________________________ SR20DET Redtop Valve Cover Normal wear and tear - nothing major - great for a core on powder coating or use it as-is. No hardware - valve cover only. $75.00 If you want a coil pack cover add $25.00 ![]() __________________________________________________ ____________________________________________ FS SR20DET GREDDY / TRUST / GREX METAL HEAD GASKET Brand New in Box I was going to use it on m SR build but need the money for more important things Part # 13521183 88 1.4mm This will work on any bore size 88mm and smaller FYI - Stock SR - Bore & Stroke 86mm x 86mm $265.00 new from Greddy http://www.greddy.com/products/engine/meta...er:make:Nissan/ GReddy $215.00 ![]() ![]() ![]() __________________________________________________ ____________________________________________ SR20DET Front timing cover with oil pump $70.00 ![]() ![]() __________________________________________________ ____________________________________________ SR20DET Bottom mount turbo manifold - turbo mounting stud will need to be replaced $70.00 ![]() ![]() __________________________________________________ ____________________________________________ SR20DET Ignitor - came off a redtop harness $55.00 ![]() __________________________________________________ ____________________________________________ SR20DET Coil pack harness - came off a redtop $45.00 ![]() __________________________________________________ ____________________________________________ SR20DET tranny to motor dust plate $45.00 ![]() __________________________________________________ ____________________________________________ SR20DET Flywheel - off a redtop needs resurface $25.00 or $75.00 resurfaced ![]() __________________________________________________ ____________________________________________ SR20DET RWD ARP Head Studs 1 torque cycle $90.00 ![]() __________________________________________________ ____________________________________________ S13 Redtop SR20DET A/C Bracket $45.00 ![]() __________________________________________________ ____________________________________________ S13 SR20DET Fuel Rail w/ caps - no injectors or FPR $30.00 ![]() __________________________________________________ ____________________________________________ S13 SR20DET T25 Turbo Lines $10.00 each or both for $15.00 ![]() __________________________________________________ ____________________________________________ S13 SR20DET Alternator Bracket - No tensioner bolt/nut $30.00 ![]() __________________________________________________ ____________________________________________ SR20DET Brand New Clutch Bolts $30.00 ![]() __________________________________________________ ____________________________________________ S13 SR20DET Throttle Bodies with Auto TPS $25.00 ![]() ![]() __________________________________________________ ____________________________________________ SR20DET Stock Crank, P/S, Alt. Pullies Crank has small chip on A/C side - Hurts nothing - Only cosmetic $50.00 ![]() __________________________________________________ ____________________________________________ S13 SR20DET Intake Manifold (Bare) $30.00 Last edited by JDS Performance; 05-17-2011 at 08:07 AM.. |
#3 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
bump for my old coil pack cover GLWS
Slip Gypsies Blog Quote:
460
