OEM outer tie rod strength?
Everyone talks about aftermarket ends but how strong are the OEM s14 ones?
I had KTS outer and the driver side one snapped on me doing a somewhat fast turn. My speedos not working so can't tell ya the speed, but I took corners like that before without a second thought, just happened to shear off yesterday. I don't have money for SPL so I want to know the strength of the OEM outer. I normally daily but I've been to 2 all day grip track events, and probably 3 canyon runs since I got my license (4years). I know canyon runnings pretty dumb but I thought I'd just throw it in there cause more the info the better recommendation I can get. |
#4 | |
So if the OEM unit does not hold up on track days, I'm just gonna buy some cheap used ones and daily on those for now. EDIT guys if you wanna help out please remember my first sentence. Last edited by johnksoy; 05-22-2011 at 01:27 PM.. Reason: did not want to double post |
#5 | |
I was leaning towards the OEM. Can I ask what you meant by beating on them. How long have you used the OEM ends for. How many events, etc... |
![]() Join Date: Nov 2006
The problem is likely not that they're weak, but chances are your car is probably too low for them to have enough movement, and they bind when the suspension compresses.
In which case spherical tie rod ends are the only way to get enough movement out of them. |
#7 | |
I guess imma buy junkyard or used online for now till I could afford SPLs. |
![]() Join Date: Jun 2008
![]() ![]() Feedback Score: 15 reviews
OP if you're on a budget get something from Autozone, they have lifetime warranties, if you break them take them back and they'll replace. Done deal. I use Tein's and I have had no issues with them, I daily and canyon run, I've had mine for 2 years now I think. Still look good last time I looked at them.
#10 | |
I wanted to know how well the OEM outers hold up cause usually OEM stuff is good quality. It seems like with the PBM setup the s14 OEM end work great. I'm a pretty good searcher but I still haven't confirmed if the OEM ends will work well on stock spindle, arms. Perfect Balance's logic makes sense. If thats the case I might as well get junk parts right now, drive lawfully, and save for SPLs. I already decided to visit the junkyard this week, looking for some other stuff too, so I guess consider this thread a done deal. If anyone wants to share there experience with OEM s14 end with stock spindle, arms, lowered. Share if you will. I thought there would be many people who'd gone through the setup I was looking for since OEM is stock. |
#12 | |
get auto zone oem outters for a s14 with oem inner for s14, they are a bit beefier and you get a LIFETIME replacement for them. so you just wait 2 weeks nad return your old shitty ones and have a set of spares if they ever fail.
OEM FO LFIE! |
#14 |
![]() Join Date: Mar 2008
![]() Feedback Score: 21 reviews
Thank you for sharing your very ingenious way of committing fraud. If OEM was so good, I'd have every piece of my car OEM. Sometimes, they just don't work out.
#15 |
ended up buying autozone, one side case closed.
After that small crashed I found out my front frame area is pushed inwards and the rivets holding it in place popped off. The other part I was looking for at the junkyard was the TCR right side bracket, which was bent. I found out the new TCR bracket i bought didnt fit because it was straight. I ended up putting the bent one back in. I'm just gonna daily this car for a while and sell it. |
