Old 05-30-2011, 12:58 PM   #1
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
CA ca18det rev limiter problem
alright so i just finished throwing in this ca18det swap in my s14 . i upgraded the stock turbo to a gt28 turbo , i am noticing when i drive the car , 1-3 gears are fine when i get to 4th gear and hit about 3100 rpm with the throttle fully open nothing happen after that point until i go under the 3100 rpm mark. its usually right before the boost kicks in in those high gears.
and when i get to 5th gear i can not exceede about 2500 rpm .
i am not sure if this would link to a maf problem. or a boost problem .
but i can pretty much red line the car in the first 3 gears and boost no problem.
some input would be nice ! thanks ZILVIA PEEPS.
Nibras is offline   Reply With Quote
boost, ca18det, s13, s14, turbo
