#121 |
![]() ^ good read on this guy's method Project - More Rubber - The Autocross Forum I machined some aluminum wheels for a concept model using a similar, but much more rudimentary method. Of course the wheels for the model were only like 4" in diameter, not 18"+ too. |
#123 |
any info on weather or not lips can be added/welded into wheels that don't come from the factory with lips? (material aside) wheels like TE37's, AME SPORTS FS-01, etc?
//ucf20\\ |
#124 |
Just built up a set of OZ futuras for a mate. New rear lips in 3.75" making the rears 11.75" wide, fronts are 9.5". Tyres got put on today so fitting time tomorrow.
#125 |
![]() Join Date: Dec 2008
![]() Feedback Score: 15 reviews
I wish he would have shown what he cut them on. My friends old shop had some lathes in it you could chuck a 24" wheel into but like atutt said, they are money and about the size of a tank.
#129 | |
#131 |
flame me all you want but i think some s13 se's polished with a 3" lip added would look baller thats just me though.
te37's with lips added?
1991 Nissan 240sx OEM+ 90's style |
#132 |
![]() Join Date: Apr 2007
i have a set of 15x7 0 Offset Epsilon mesh wheels. if i wanted to get them widened an inch or two they would do it from the back im assuming making it a more negative offset correct? is there a way to do it to where it could become positive?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
#134 | |
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
it will actually become more positive if added in the barrel not lip edit: damn u beat me ^ |
#135 | |
#136 | |
Fronts are a bit crazy!!
#138 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
no because you are making the wheel wider but not changing the position of the face relative to where it started. thus adding more wheel to the outer lip will push the face in relative to the wheel's new width.
#139 | ||
![]() Join Date: Dec 2005
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
#142 | |
![]() I'll drop you a pm.
#143 | |
overall they both meant that adding more lip lowers offset. because you are comparing the location of the center piece in relation to the new overall size of the wheel. so if you had 5 inches of rim on inside barrel and 3 on outside your offset would be XX and if you reduced the size of the inner barrel and increased the size of the outer barrel, you would now have -x offset(lower)
#145 |
Trader Rating: (53)
i just re-read it again, he is asking if you HAVE to take away from the backside and then add to the front side to make it more negative; and the answer is NO, you do not. Simply adding more material on the front side will make the wheel's offset more negative relative to it's new width.
#146 |
![]() Join Date: Nov 2007
wow...offset is really easy to understand.
it's measured in correlation to the center of the wheel. 18x8 0 offset (4 inches on each side of center) 18x10 0offset (5 inches on each side of center) add one inch to the face of 18x10 now equals 18x11. a zero offset will have 5.5 on each side of center. If the mounting point was zero offset at 18x10, adding one inch changed the location of where the center of thr rim is. Now you have to measure from center (0 offset) to the location of the mount (which was zero offset on a 18x10 now 18x11) in which 25mm equals about an inch, you should have a rough -12 offset (add one inch is half an inch on either side of center (zero offset). offset is measure from center to the mounting position. Measure in mm. positive offset if mount is past the center (less lip, more back spacing) and negative is opposite (more lip, less backspacing). I hope this helps ;D |
#147 |
Trader Rating: (53)
if you add an inch only to the front wouldnt the new mounting position essentially be 25mm less than what it was before? now making your 18x10 +-0 wheel into an 18x11 -25.
im having trouble seeing how adding an inch (25mm) to the front is only going to effect the mounting position by 12mm... |
#148 |
Yes, but that gets expensive, if you had centers from a flat dish 17" wheel it's possible that you'd be able to put stepped lip onto it from an 18" but that means new barrels and lips.
#149 |
Trader Rating: (55)
heres a thread that sort of explains sizes of relipping How to build your BBS RM and RS - Bimmerforums - The Ultimate BMW Forum
#150 | |
i suck at math and wont try to verify it lol..but he did make it sound simple to the guys who were arguing about it.
