Originally Posted by chiboy002
Hey Toby, where do you buy your abs plastic? I bought some 1/8" thick online and it sucked. It would have so many burrs when cut and they edges wouldn't come out nice and clean
You are simply not putting in the effort man. After you cut with a jig saw or whatever you are using, then I go over it with 80 grit then work my way down to finer grits to get a perfect polished edge if necessary. I may start with a bench belt sander or an air sander to get the burrs off quickly. Nothing custom comes easy man. You have no idea how much time I have into the custom interior stuff I do. I might sit there and sand with a finger tip for 3 hours straight just to get a contour perfect.
Also, use a coarse blade when cutting. If you use a blade for cutting metal, it will simply melt the plastic as you are cutting it. So when I'm using a jig saw, I use a gnarly wood blade, but set the orbital action to the lowest setting and just go slow physically.... still fast speed on the trigger though. This will give you a fine cut, but not melt the plastic too much.
