Old 06-10-2011, 12:08 PM   #1
flushALA$
flushALA$ is an unknown quantity at this point
I get a TICK every 4 seconds on my newly SWapper SR
I recently got a swap from a ka to an SR20det from jdmnagoya.com and it seems i get a tick sound every 4 seconds...is this a rod knock or a bearing??or possibly a washer or part of something that fell into the cylinder head, causing it hitting the pistons??
flushALA$ is offline   Reply With Quote
Old 06-10-2011, 12:18 PM   #2
curbhuggerrps13
curbhuggerrps13's Avatar
curbhuggerrps13 is an unknown quantity at this point
Send a message via AIM to curbhuggerrps13
record it and upload. can be many things
curbhuggerrps13 is offline   Reply With Quote
Old 06-10-2011, 12:51 PM   #3
flushALA$
Will do they said they haven't put the Downpipe on their yet but we'll see they couldn't tell as of now.I get the car tomorrow and will record it.ty
Old 06-11-2011, 02:33 PM   #4
NIZzS13
NIZzS13 is an unknown quantity at this point
Where does it sound like its coming from, i know you said the head but from the front or back. If its a ticking sound that only happens at idle and it sounds like its coming from the front of the valve cover, then it could be your upper chain guide. A common thing, just remove the valve cover and remove the 2 12mm bolts holding it and your done. Most sr's get them taken out for the same reason.
NIZzS13 is offline   Reply With Quote
