Old 06-10-2011, 08:40 PM   #1
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
S13 LCA bushing Replacement - w/o damage?
Looking to install S13 LCA's back on my car and I have new E/S bushings for them but from what I understand from a friend, using a press may crush the arm??
Is there a non-destructive way to remove the old ones with a press or maybe w/o??
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 06-10-2011, 08:57 PM   #2
Jukebox
Jukebox is an unknown quantity at this point
Burn em out w/ a propane torch is one way...
Jukebox is offline   Reply With Quote
Old 06-11-2011, 12:31 AM   #3
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
Burn them out with torch and use a saw to cut the outer sleeve.
P.S. ES bushings in the LCAs is a bad idea.... Rubber or sphericals are best to avoid binding.
az_240 is offline   Reply With Quote
Old 06-13-2011, 10:57 AM   #4
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^ If your traction arm is set up correctly, that should never been an issue.
The fronts can only be burned out since its the only ES bushing that retains the outer metal sleeve. READ THE DIRECTIONS.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 06-13-2011, 06:29 PM   #5
az_240
az_240's Avatar
Trader Rating: (41)
^What? ES bushings in the uprights/LCAs will bind no matter what. The poly material has too much friction to it and does not allow the inner metal sleeve to rotate freely when the suspension travels making the ride complete shit...even when they are well greased.
You are better off getting rubber Nismo bushings for the FLCAs... they are only like $10 each at the dealership. The Nismo RLCA bushings (s14) are near impossible to find these days though. I've been searching for the past 6 months for some at a reasonable price and have found nothing.
Old 06-13-2011, 06:52 PM   #6
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
honestly I've heard that same thing about the tension rod Bushings and Other Stuff (like J30Diff can't use standard D/S,etc etc) like that Truly plays the telephone game: ie. 1 or 2 people having a problem with something and It transforming into more extreme Issue.
Either way....Its gonna def be better than the bushing that's in this Turd!
I literally just saw the part about "using heat" to remove it.
just wanted to make sure before i trashed these things I spent so much time on welding/Boxing in and Cleaning.
z-tERty-2
Old 06-13-2011, 07:04 PM   #7
az_240
az_240's Avatar
Trader Rating: (41)
^Actually I'd rather have shitty stock bushings over ES any day if it's ever driven on the streets.
The ES tension rod bushings are built differently (3piece) and won't bind as bad.... they are still crap IMO.
Old 06-13-2011, 07:13 PM   #8
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
herp derp moment...
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 06-13-2011, 07:20 PM   #9
az_240
az_240's Avatar
Trader Rating: (41)
^No it's a 2 piece (not including the inner sleeve)... unless they came out with a new design.
Old 06-13-2011, 07:23 PM   #10
DreamN
DreamN's Avatar
Trader Rating: (54)
Edit:
nevermind, i searched really quick. you're right bro.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 06-13-2011, 09:18 PM   #11
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
i just put one on my w14 yesterday due to this issue http://zilvia.net/f/s-chassis/390483...aking-s14.html.
I used butane torch to burn old bushing out and install new ones with C-clamp. You do not need press to install new bushing nor you don't even need to take the ball joint out.
Loosen bolts for LCA and tension rod and sway bar. thats all you need.
refer this one Energy Suspension Bushing Installation Guide
Old 06-14-2011, 02:33 PM   #12
s14unimog
s14unimog's Avatar
Trader Rating: (22)
ya, the fronts go in without a press. If you do the rears however, you'll need an arbor press.
