Old 06-13-2011, 09:55 PM   #1
sidewayzsilvia
sidewayzsilvia's Avatar
sidewayzsilvia is an unknown quantity at this point
s13 fuel leak
Got home work today and noticed that fuel is leaking from the bottom of the vapor canister, is this thing junk? Looks like return line back to the tank runs through the canister? Any answers or ideas
sidewayzsilvia is offline   Reply With Quote
Old 06-13-2011, 10:13 PM   #2
AutechKouki
AutechKouki's Avatar
Trader Rating: (43)
AutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura about
Feedback Score: 43 reviews
You top off your gas tank when you refill? Thats the only reason I can think of that your charcoal canister would be full and spilling it out.
And it's not a return line, it's basically like a breather for your gas tank, it can be deleted with a plug and a clamp on top of the gas tank.
AutechKouki is offline   Reply With Quote
Old 06-13-2011, 10:33 PM   #3
sidewayzsilvia
I pulled the 3 hose coming off of the canister, 1 vacuum, 1 line back to tank, on bigger
Hose there was gas coming out of that line. It had some pressure behind it but not a lot.
Old 06-13-2011, 10:43 PM   #4
AutechKouki
Trader Rating: (43)
Yeah, it was pressure from your tank.
Oh and if you're going to delete it plug up your vacuums.
Old 06-13-2011, 11:04 PM   #5
sidewayzsilvia
Removed gas cap and sure enough the tank was under pressure, think I need a new fuel cap?
Old 06-13-2011, 11:06 PM   #6
AutechKouki
Trader Rating: (43)
Haha. No that's a good sign. It should be under pressure.
Old 06-13-2011, 11:13 PM   #7
sidewayzsilvia
Never had a problem before when filling my gas tank, until now. I placed a bottle to collect the fuel come from the line off of canister and as soon as I pulled fuel cap off and relieved pressure the fuel from line stopped. Where is the tank vented, maybe the vent is stuck closed
Old 06-13-2011, 11:20 PM   #8
AutechKouki
Trader Rating: (43)
It vents fumes through canister.
Personally I think your tank is just overfilled. Don't top off when you fill up, just until the pump clicks off. Topping off causes the charcoal canister to saturate and leak out.
Old 07-08-2011, 04:22 PM   #9
sidewayzsilvia
CA
Update:
Still haveing the same problem, haven't topped off tank since. Even at 3/4 of tank and its above 80 degrees I get raw fuel pushed through vent line and out of charcoal canister.
Old 07-08-2011, 04:33 PM   #10
sidewayzsilvia
CA
Update:
Old 07-09-2011, 11:04 AM   #11
sidewayzsilvia
Is there some sort of check valve or something to stop fuel from being pushed that far into the system?
Old 08-03-2011, 05:17 PM   #12
sidewayzsilvia
Update
Redplaced the fuel check valve in vent line. Still have same problem, anyone have any other ideas????
Old 08-04-2011, 03:18 PM   #13
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
What about the possibility of your fuel gauge or sending unit not sending a correct signal causing you to fill too much?
Old 08-04-2011, 04:25 PM   #14
sidewayzsilvia
Never thought of that I guess, when I do fill it I stop after the pump clicks off the first time. What cause cause fuel pump to shut off
Old 09-03-2011, 07:45 PM   #15
uhhh-s13 again
uhhh-s13 again is an unknown quantity at this point
you ever solve the problem. my car started doing the same thing today. i dont have the canister and i have a sr, so my gas tank breather is just ends and is open by the starter and the rest of the fuel lines. never did this till today.
uhhh-s13 again is offline   Reply With Quote
Old 09-03-2011, 09:24 PM   #16
sidewayzsilvia
No I haven't figured it out yet. I just don't fill my tank over 3/4 of a tank.
Old 09-16-2011, 12:33 AM   #17
uhhh-s13 again
That sucks. I think its something to do with the vac system and blowby. Mine started doing it the day I put my new pcv valve in.
Old 10-02-2011, 01:15 PM   #18
MyNameIs-dRu
MyNameIs-dRu is an unknown quantity at this point
Hi guys,
Thread jack but I hope to get some help here.
I'm having a massive leak and it seems like it's coming from behind the block and firewall but I can visually see it. I see it leak around that area and tried from underneath and above the block to pin point it but it's so hard.
Anyone got a clue or had this issue. Is my gasket blown?
-Noob Owner of a 93' 240sx
MyNameIs-dRu is offline   Reply With Quote
Old 10-02-2011, 01:19 PM   #19
AutechKouki
Trader Rating: (43)
Fuel right?
It's going to be most likely the fuel pressure regulator seal, or return line. Maybe even your fuel hard lines.
Old 10-02-2011, 01:23 PM   #20
MyNameIs-dRu
Thumbs up
Yeah Fuel.
Thank's for the input SDV. I'll have to dig in some more under the Texas Heat
Old 10-02-2011, 01:26 PM   #21
AutechKouki
Trader Rating: (43)
An easy way to create fuel pressure is to put your key in the on position by cycling the key on and off. That way you don't have to turn on your engine.
Old 10-11-2011, 02:57 AM   #22
uhhh-s13 again
Took my mbc off. No more blow by and no more fuel leak. The weather is alot colder out now though.
