![]() Join Date: Jul 2009
Trader Rating: (50)
![]() Feedback Score: 50 reviews
ka oil pan removal
i need to tap into my ka oil pan for a oil return tube.
whats the easiest way to remove the oil pan so i can weld the return bung on? any tricks
wtb s14 roof wing/spoiler! pm me |
#3 | |
![]() Join Date: Oct 2009
Trader Rating: (72)
![]() Feedback Score: 72 reviews
![]() no but all jokes aside i couldn't do it. but i can unbolt the mounts and lift the motor with a hoist. but putting it back in is not east and it might not seal right. and theres bolts under the the cross member. its a pain just pull out the motor best way for me.
95 s14 ka DD |
#5 | |
Trader Rating: (50)
![]() your an idiot.....
![]() Join Date: Mar 2007
Chain up the engine and lift it a little bit, you should be able to get all the bolts off and seal it back on correctly. Unbolt the engine mounts and tranny.which is pretty much pulling out the engine
Obliterate |
![]() Join Date: Sep 2006
Trader Rating: (29)
put the car on jack stands remove radiator and fan shroud then
1.unbolt engine mounts from bottom 2.remove lower tranny to engine braces from both sides 3. place jack under transmission and raise it up 4 remove all the 10mm bolts 5. drop pan slightly unbolt oil pick up 6. remove pan
#11 | |
Trader Rating: (50)
Yeah thats the plan ![]()
#14 |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
Mine would have better value compared to "stillnojob" I'll be like spl and he will be like Megan racing...
Here some pics of a pan I did for one of the members here ![]() ![]()
NEED Bolt kits for your car? |
#15 |
![]() Join Date: Oct 2006
![]() ![]() Feedback Score: 23 reviews
All you do it loosen the top nut on the motor mounts. Leave them threaded a little at the top, but do not loosen them all the way. Jack the car where the motor meets tranny and it will be high enough to slide the oil pan out. Did not need to remove anything, besides tilting the sway bar forward to give some extra room. It will be a pain to unbolt the oil pickup and put it back on, but it is doable. Use a felpro gasket, not gasket maker and it will make your life much easier putting it back on if you use this method.
#16 |
![]() Join Date: Apr 2009
Trader Rating: (46)
![]() Feedback Score: 46 reviews
its more work to take off the steering rack/front subframe but its worth it since you have room to work under there. thats what i did when replacing the pan and oil pick up.
#19 | |
Trader Rating: (82)
yeah no problem 323-712-0592... i have yet to run the turbo u sold me! lol
#20 |
![]() Join Date: Jan 2011
Remove mount bolts, raise motor by the tranny making sure no lines gets pinched on the fire wall...remove pan.
easy...
Simplicity is the key to brilliance |
#23 | |
