Old 07-19-2011, 11:43 AM   #1
240sx-pat
240sx-pat is an unknown quantity at this point
Send a message via AIM to 240sx-pat Send a message via MSN to 240sx-pat
Car does not start after wire loom help!
Hey guys i need your help this is probally the dumbest shit I've done with my SR I took the harness out and tried to loom it but failed my car won't start now.
I can hear the pump prime when I turn the key all the dash likes are on but it would just crank but does not turn over..which wires do you suggest i look over and see why it isn't turning over I would hate to tear this whole thiing apart so I''m trying to see if anyone is familar with the wiring
240sx-pat is offline   Reply With Quote
Old 07-19-2011, 12:00 PM   #2
timinthehood
timinthehood's Avatar
timinthehood is an unknown quantity at this point
do you hear just clicking from your starter? check ground?
i'm the kouki monster
timinthehood is offline   Reply With Quote
Old 07-19-2011, 12:22 PM   #3
240sx-pat
Nah I don't hear any clicking from starter I hear it cranking and the ground was good the car ran fine until I took the harness out. It is something in the harness I'm just not sure were to look
Old 07-19-2011, 12:55 PM   #4
ultramagnus
ultramagnus's Avatar
Trader Rating: (41)
ultramagnus is an unknown quantity at this point
Feedback Score: 41 reviews
So fuel pump is ok, how about any other accessories related to ignition you might have unplugged the wire, check w/ test light on the ignition harness see if you have juice going to that side of the car.
"Consistency is Victory"
ultramagnus is offline   Reply With Quote
Old 07-19-2011, 01:33 PM   #5
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
u missed a ground somewhere im guessing
how much of the 'harness' did you take out?
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 07-19-2011, 04:32 PM   #6
240sx-pat
Yea, the fuel pump is okay, I can hear it prime like it suppose to but I went wrong somewhere. I can check but when you say the ignition harness are you referring to the 2 plugs that connects on each side of the ignitor chip? I because I did depin those plugs so hopefully they lined up like they are suppose to?
fuck if anyone can take photos of their plugs I'd appreciate it just so i can match mine up
Old 07-19-2011, 04:53 PM   #7
240sx-pat
A ground in the harness itself? i only depined a few pins from the harness and just kind of router them through the sleeves. I double check the ECU pins just to make sure all the colors were lined up in the ECU pin..
and I depin and took out some what i thought were unused
like pin 41
A/C on input (Air Con ON from A/C panel)
Blue Green
43
Power steering switch (speed proportional control output)
Purple White
and this green/yellow wire (I A/C )45
Pin
Ambient air tamp sensor input
Blue White
and
and theres this blue/red skinny wire that is not connecting to anything but it goes to one of the plugs near the injectors
here's a photo
I don't remember ever having this plug soldered , this is one of the wire that goes to the grey plug that connect to the chassis I just taped it off.
this is the wires/plug that I completely removed
Old 07-20-2011, 09:12 AM   #8
bb4_96
bb4_96 is an unknown quantity at this point
Take the plugs and coil out of the cylinder and see if it is firing. Get a test light and check your injector plugs. If you shortened wires make sure there aren't any loose ones. Do a pin to pin continuity check on the ecu plug to accessory plugs. The FSM has pinouts for connectors if not google image search for sr20det plugs/pinouts etc and get some of Jordans old crayon pinout sketches.
bb4_96 is offline   Reply With Quote
Old 07-20-2011, 03:35 PM   #9
conrad_s13.5
^yes!
also, triple check for possible missed grounds
im sure u kno u checked, but you never know.
maybe engine needs more ground. Grab jumper cables and ground engine to chassis really quick and try
never know
cONtRol FReAkS
Old 07-20-2011, 03:38 PM   #10
conrad_s13.5
ecu also has single red(?) wire it needs JUST to start.
Dnt know of the top of my head which ones they are but i have them written down as important...lol
pins:
46
109
34
36
104
4
38
47
check em out
cONtRol FReAkS
Old 07-22-2011, 11:55 AM   #11
240sx-pat
Yea all those pins are good, hey quick question? do all the injectors have the match the harness? or could I plug them in any order. What I'm asking is if FSM say white/black goes into first injector and I plug it in 3 will it matter?
Old 07-22-2011, 02:57 PM   #12
240sx-pat
HAHAHahahahahahahahaHAHahhahaahahahaHAHAHA OHOHOHOHOHOHOOHHOHOHOHOHHHO OHHHHHHHHHHHHHOHOHOH!!!
Okay guys I'd thought I'd come in here and expose myself for being such an idiot. The cas and my plug are both broken so it's hard to tell which way its pluged it. It does not clip well I ended up having this stuff plugged in backwards so that was the problem!! LOL thanks for your help
