Old 03-11-2004, 10:51 AM   #11
aznpoopy
aznpoopy's Avatar
i'm not well read on sohc chain rattle but i know its a SERIOUS problem. you should really do some research and fix that asap. this doesn't sound totally like your problem ... but here ya go.
240sx.org FAQ on SOHC rattle :
(Regarding SOHC engines)
Q: 1) is the '89 240SX SE an 'interference' engine (timing belt goes, valves and pistons crash catostrophically) or not?
A: Yes. If your chain breaks (never happens) or starts jumping teeth on the gears (more on this later) it can munch the valves.
> Tony Iannarelli wrote:
> > What are the symptoms of the Timing Chain going bad?
> Well, it's not so much that the chain goes bad, but the tensioner
> gets weak and the guides break into little bits. This is a Nissan
> technical service bulletin, which means it's a known problem and
> there are upgraded parts available to correct it, but it's not a
> recall, so you have to pay to have it done.
> The usual symptoms are that the engine rattles like hell when you
> first start it (chain flapping around) and lacks power (slack chain
> causing camshaft timing to drift around unpredictably).
> It's a 10-12 hour job for your typical do-it-yourselfer, but it's one
> of the more annoying jobs I've done on my car. If you can afford it,
> I would advise you to have a shop do it -- and the independent shops
> do just as good a job as the dealerships, for less money.
