Old 08-24-2011, 07:55 AM   #1
s14drifter1
s14drifter1 is an unknown quantity at this point
S14 Sr20det Engine, PTE5857 BB Turbo, Mazworx VG to SR, Wolf 3d Standalone ecu Plug..
Engine
S14 SR20DET Variable valve timing system
Brand New Block 6,000 Miles
ARP Head Studs
Power Enterprise Head Gasket with Fire Rings
Block Rehoned
Valves Reseated
Engine Ported
Crank Journals Polished
ACL Race Bearings
Forged JE Pistons
Eagle Rods
Tomei 270 Solid Lift Cams
HKS Lash Killer Kit
Brian Crower Springs and Retainers
Sr20det Steel Flywheel Resurfaced
Greddy Oil Catch Can
Monkey Magic Engine Mounts
Uras CAS Guard Cap
Uras Oil cooling Block
Remote oil Filter Relocation Kit
Brand New Oil Pump
Brand New Water Pump
New Timing Chain kit
Greddy Pully Kit
Power Enterprise Power Steering and Main Belt
Engine- $2000
Wolf Stand Alone Engine Management System , Plug & Play (car is tuned for 93 Octane, I also have an E-85 Map) with 5 Bar map sensor $ 700
Zenki Engine Harness
Wiring Done by Wiring Specialties Yuri- $250
Full Race Tubular Pro Race Manifold (Life Time Warranty full race)
Full race down pipe 3 inch- $800
Precision Dual Billet Wheel Ball Bearing Turbo 5857 Ported Surge Housing Rated at 605hp, .63 A/R, Just brought last month...- $1000
Front Mount Intercooler Kit 3 in- make offer
Tial Blow Off Valve 50 MM- $160
Tial 44 MM Wastegate 18 PSI spring- $250
Split Fire Direct Ignition Coil Packs W/ Amplifier - $280
Circuit Sports Grounding Plate- make offer
Auto Meter Boost, Oil Pressure, and Air Fuel Gauge, Battery, Water Temp, Oil Temp, AEM Air Fuel- Make off
Greddy Intake Manifold Generation 2 (1 Piece Manifold not 2) with Fuel Rail for Top Feed Injectors and 90mm throttle body- $800
Greddy Type S boost Controller- $250
Greddy Turbo Timer- make offer
Mazworx VG to SR Conversion Kit with 300zx Transmission $ 900
ACT Unsprung Clutch $200
Email me: [email protected] located in Brooklyn, NY. Any questions, call me at 917-873-5415
Shoot me Offers...
I'm going with LS1 setup..
s14drifter1 is offline
Old 08-24-2011, 08:18 AM   #2
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
So i see your not selling your car good luck on build. If u need any help with ls1 builds lmk. I reccomend going sikky everything unless you wanna go custom
blueshark123 is offline
Old 08-24-2011, 07:51 PM   #3
s14drifter1
Thank you, I was thinking about sikky parts too...
Old 08-24-2011, 08:30 PM   #4
MrJdmEh2
MrJdmEh2's Avatar
MrJdmEh2 is an unknown quantity at this point
Why is there always good ish for sale when im low on cash.. Good luck on your sale.
MrJdmEh2 is offline
Old 08-25-2011, 08:34 PM   #5
s14drifter1
S14 Sr20det Engine for $2000. S14 & S15 Greedy intake manifold 2nd Generation with 90mm throttle body, and fuel rail for top feed injectors $800 .....Wolf EMS Standalone with hand controller and memory card.. $ 700
Old 08-26-2011, 10:34 AM   #6
s14drifter1
Greedy intake manifold with Throttle body, Fuel rail, and Full race manifold setup- sold. Still have the ball bearing PTE5857 billet turbo (605hp) for sale $1000, Engine for $2000, and Mazworx transmission kit with Transmission for $900
Old 08-26-2011, 01:35 PM   #7
z32ttvert
z32ttvert is an unknown quantity at this point
Engine
ARP Head Studs
Block Rehoned
Valves Reseated
Engine Ported
ACL Race Bearings
Forged JE Pistons
Eagle Rods
HKS Lash Killer Kit
Uras CAS Guard Cap
Brand New Oil Pump
Greddy Pully Kit
Engine- $2000
What's the story on this motor, who built it?
z32ttvert is offline
Old 08-27-2011, 03:59 PM   #8
s14drifter1
The motor is a good motor, my tuner reffered me to a guy that usually builds his customers engine. His names Jean Duvert.. Jean built many people engines in the Tristate area... This engine is solid..the only reason why I'm selling it is because I'm going LS1.. I Made 407 hp @17 PSI on 93 octane and I made 537 hp @27 PSI on E-85... The reason why I'm selling the engine cheap is because I want to sell it quick so The money can help me pay for the LS1 swap...
Old 08-27-2011, 04:08 PM   #9
s14drifter1
Wolf sold....
Old 08-27-2011, 04:20 PM   #10
Ben10
Ben10 is an unknown quantity at this point
Do you have s14 sr maf for sale by any chance?
Ben10 is offline
Old 08-28-2011, 04:32 AM   #11
s14drifter1
I'll check in my basement but, the wolf worked on speed density...
Old 08-30-2011, 05:59 AM   #12
s14drifter1
Transmission kit sold.
Wolf sold..
Splitfire ignition Sold...
I still have a s14 sr20det engine built.. For $2000
I have a Precision Turbo that is two months old with low miles..PTE5857 Dual Ball Bearing Billet Wheel Turbo for $1000..
Tial BOV 50 mm $160
Tial 44 mm wastegate $250
Act unsprung Clutch $200
Greddy Type S boost Controler $250
Please shoot me offers!
Old 08-30-2011, 01:21 PM   #13
Lostinthegame
Lostinthegame is an unknown quantity at this point
Do you still have the full race manifold and down pipe??
Lostinthegame is offline
Old 08-30-2011, 10:36 PM   #14
s14drifter1
No I'm sorry the full race manifold is sold..
Old 08-31-2011, 05:40 PM   #15
racerx2k1
460
racerx2k1's Avatar
Wolf sold....
Wolf sold..
Tial BOV 50 mm $160
racerx2k1 is offline
