Old 10-01-2011, 06:16 PM   #1
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Mishimoto Fan Shroud Fail
On a buddies car about 6 months ago we installed a Mishimoto fan shroud on a Mishimoto radiator.
The design of the mounting points for the fans on the Mishimoto fan shroud had me concerned and confused since the beginning. The fact that the fans were allowed to move towards the fins on the radiator was rather strange. I thought it would be better for them to be stationary instead of moving around. Apparently they have moved around enough to penetrate the radiator core. We noticed that the coolant reservoir was low and did not know why it was slowly going down over the course of a few weeks. I decided to check the radiator and saw that it was low in there as well, we added about half a gallon of coolant in the Mishimoto radiator and decided to start the engine and check for leaks.
We were talking about it possibly being the headgasket because it was recently changed and thought it may not have sealed properly. However, when we started the car and the thermostat opened up we saw little drips coming out of the fans. We assumed it was just some coolant that we had spilled out so we dried the fans off with a towel and started it again. It was indeed leaking from somewhere, after shutting it off after a few revs we noticed a steady stream coming out of the radiator in two places right near the sharp edges of the mobile fan brackets.
:frown:
I'm not sure who the program manager for this project was but the engineers need to reconsider their design.
om3ga is offline   Reply With Quote
Old 10-01-2011, 10:01 PM   #2
ZAKU
ZAKU is an unknown quantity at this point
Originally Posted by om3ga View Post
Mishimoto... ...engineers
Haha, you're a funny guy.
ZAKU is offline   Reply With Quote
Old 10-01-2011, 10:14 PM   #3
Boost_Fiend
Boost_Fiend is an unknown quantity at this point
Ive been running the same setup for a few months now. I haven't had any problems with it at all. Mishimoto has a lifetime warranty on their radiators thats pretty legit. They will replace it even if you get into an accident.
Boost_Fiend is offline   Reply With Quote
Old 10-01-2011, 10:21 PM   #4
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
I just picked on up myself. The mounting quality is indeed inaccurate. i had to massage the points into place very slightly, and it bolted on. However, it does sound like a potential issue, since aluminum is soft and easy to bend. over time im guessing, with my very tiny amount of knowledge, that it could stretch something.
Is this how yours was also when you first installed it?
chetacheese is offline   Reply With Quote
Old 10-02-2011, 07:39 AM   #5
Matthew Murphy
Matthew Murphy is an unknown quantity at this point
koyo rad and flex-a-lite fans next? that wont happen to them
Matthew Murphy is offline   Reply With Quote
Old 10-02-2011, 07:54 AM   #6
eighty-six
eighty-six's Avatar
eighty-six is an unknown quantity at this point
I had the same problem happened to me awhile back, i informed the dealer i got it from and they sent me a new radiator right away. Their warranty is pretty legit.
"Team Abunai 671"
eighty-six is offline   Reply With Quote
Old 10-02-2011, 08:53 AM   #7
stance
stance is an unknown quantity at this point
oh yea?........
stance is offline   Reply With Quote
Old 10-02-2011, 11:46 PM   #8
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Feedback Score: 79 reviews
Hmmm this is good to know I was just about to buy one too
jdm2191 is offline   Reply With Quote
Old 10-03-2011, 12:42 AM   #9
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
i have the same shroud and I noticed that the fans could move forward while installing them...so instead of hoping that something didn't go bad. I put epoxy in the mounting brackets and pulled the fans back away from the rad where they are supposed to sit. Not a big deal....accident prevention
huffandpuff00 is offline   Reply With Quote
Old 10-03-2011, 05:23 AM   #10
Skilz10179
Skilz10179 is an unknown quantity at this point
I just bought the same set up (radiator, fans and shroud) but haven't installed them yet. How about some pics of the actual damage where the fans contacted the radiator?
Skilz10179 is offline   Reply With Quote
Old 10-03-2011, 07:41 AM   #11
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
Mishimoto has great customer support, if you haven't tried calling them yet I would highly recommend doing so. I was given a Mishimoto radiator for free that had a drain plug that the head had broken off of. I called Mishimoto to purchase a new drain plug and instead they mailed me one for free, all I had to do was removed the old one, which was stupid easy.
That has instilled some appreciation in them for being super easy to work with over the phone, at least try calling them to see what they will do for you.
onehundredoctane is offline   Reply With Quote
Old 10-03-2011, 09:38 AM   #12
eighty-six
eighty-six's Avatar
Here's a picture of mine after the fans touched the fins of the radiator. I couldnt find the leak so i kept pouring water in until i found it.
"Team Abunai 671"
Old 10-03-2011, 10:01 AM   #13
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
Simple thing to do was run a bead of RTV on the backside and front of the fan clips when they are pulled away from the the shroud as far as it goes... Some foresight on your end could have been used.. But that does not help your situation, as 100 said get the warranty honored they are legit for customer service!
mattack69 is offline   Reply With Quote
Old 10-03-2011, 10:09 AM   #14
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
I will take a picture of how I mounted mine on the shrowed, I don't thin I will have any problems
idahotuner is offline   Reply With Quote
Old 10-03-2011, 10:55 AM   #15
Chay G
Chay G's Avatar
Chay G is an unknown quantity at this point
Send a message via MSN to Chay G
That happened to me, i was runing dual speed jetta mk4 fans on oem radiator, so i upgraded the radiator and installed spacer on the fans now they are 1" away from it, i think if you install them on the other side of the shroud you should have enough clearance
Chay G is offline   Reply With Quote
Old 10-03-2011, 08:00 PM   #16
Skilz10179
I just went out to the garage to check my set up. I think they may have changed the design, my fans are at least a half away from contacting the radiator core.
Old 10-04-2011, 06:19 PM   #17
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Time to epoxy that hole....that shit worked on my Sr rad for almost 2 yrs till I finally got the motivation to get it rewelded up.
CLICK HERE!!!
Old 10-06-2011, 09:42 AM   #18
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
OP, you have the old design. They changed there design on the fan and shroud. I have the new version and the fans are mounted on top of the shroud, that way they will never be in contact with the radiator.
Mishimoto will send you a new radiator with no questions asked.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 10-07-2011, 12:09 AM   #19
Dpacro001
Dpacro001 is an unknown quantity at this point
don't buy 3rd party copy from china and it wont happen.
Dpacro001 is offline   Reply With Quote
Old 10-09-2011, 04:04 AM   #20
om3ga
om3ga's Avatar
Mishimoto has great customer service and good quality products which is why i see them as such higher quality than Godspeed, CX Racing companies. I don't typically buy from low quality companies on any of the builds i do but these guys stood out as a bit higher quality above others as well as great customer service.
Eighty-six, that is an awesome picture. Exactly the same area where ours had a problem.
They have honored the warranty and sent out a replacement shroud (Which has been redesigned) as well as a new radiator and cap.
The only reason i posted this up was to give other possible users visibility on this issue to maybe prevent it from occuring with their setups.
