Old 10-06-2011, 03:38 PM   #1
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
What do you mean Wet and Dry Test? Dropped oil in the cylinder? If thats what you meant, just having a blown HG wouldnt bump your compression.
CLICK HERE!!!
Old 10-06-2011, 08:05 PM   #2
jakez
jakez is an unknown quantity at this point
Yeah wet test as in a squirt of oil in the cylinder. I thought they were called dry/wet. You're saying the head gasket should be fine? 125 seems awfully low
'93 240SX SE Coupe SR20DET Red Top / '06 300C SRT-8 / '03 E55 AMG
jakez is offline   Reply With Quote
Old 10-06-2011, 08:14 PM   #3
s14fbs
s14fbs's Avatar
s14fbs is an unknown quantity at this point
Send a message via AIM to s14fbs
sounds like u need rings reguardless with that low of a compression
u should do a leak down test
and maybe invest in a fan controller
s14fbs is offline   Reply With Quote
Old 10-06-2011, 08:34 PM   #4
fliprayzin240sx
I'm saying a blown HG is the least of your worries. When you drop oil in the cylinder, it doesnt seal up the HG, just the rings. So just the fact that it bumped up means its sealing the rings.
Disconnect the crankcase hose to the T on the valvecover...I got a feeling you got some smoke coming out of there, or atleast got air pulsating out. That means air is getting thru the rings and pressurizing your crankcase...that means rebuild time.
CLICK HERE!!!
